I thought it was. I find my Chota mukluks are waterproof for a few minutes. If I stand in the water longer than a few minutes, I start to feel a minute amount of water seeping through.
Is it coming through a hole or a seam, or does it seep through the neoprene itself with longer immersion?
Boots are a few years old. I never noticed this problem before, but I never stood in the water for very long until recently.
Pretty sure
the material is waterproof.
Leaky boots
Neoprene boots are waterproof.
You have a hole somewhere.
Fill the boot with water and hold it up.
Let it dry thoroughly, then patch with Aqua Seal (Dive shops) or Amazing Goop" (Home Depot).
It’s an easy fix.
If you feel it’s soaking through along a
seam, you can use SeamGrip, runny cousin of Aquaseal. It is thinner and is designed for soaking into and waterproofing tent seams.
I had to seal portions of the seams …
… on the neoprene portions of my Gore-Tex Chota boots, and just recently discovered that I need to do the same on my all-neoprene Chotas. Both were waterproof when new, but after many years of use the seams must have gotten a little “looser”. A slight bit of leakage through seams when new would not surprise me at all though. Find the exact location of the leak by filling them with water and observing where the water oozes through, and fix it. It wouldn’t hurt to seal more seam area than you think you need.
seal the seams
An unfortunate common problem with Chota’s, they’ll start to leak along the seams.
I used Aquaseal and sealed all the seams on the inside
(as best as I could) and out. It took only a few minutes of time and made the boots much more reliable.
Typical for you !
You were recently proclaiming that the Choata’s “kept your feet warm and dry”, and were telling another poster to get them.
You might want to consider not recommending something until you have used the item for several years
Guy
Same with gloves
I never had a neoprene glove that didn’t leak after a few paddles. I always have to seal the seams with Aquaseal. Even brand new they sometimes leak. I guess getting an edge to edge seal with thin neoprene is not easy?
I’ve had my Chotas for years and they
don’t leak.
Maybe he has…
Someone who paddles every day is harder on gear than someone who paddles twice a month.
Lets put the timeline into "use days.."
I have put on some five hundred uses on my Chotas and now they do leak. They still keep my feet warm. My feet are never dry. In shoes my feet sweat.
leak
I have stood in the water for some time and never gotten a hint of a leak with my Chota mukluks. Do both of your boots leak, or just one. If only one, I would suspect a leaky seam, or maybe a leak in the sole.
Compression failure
Dear Board
All neoprene footwear will leak from compression failure over time. How soon and to what degree depends on the amount of compression force that is exerted.
This I know for a fact because every single pair of waders I have owned over the last 25 years has leaked in the soles of the feet. Some waders took longer than others, but they all failed eventually.
Regards,
Tim Murphy AKA Goobs
Well, not “all” neoprene footwear
It sounds like you are talking about waders with stocking feet, designed to go inside boots (that’s my take on your use of the term “compression failure”). Paddling boots have no such issues, since the neoprene never gets “squashed” that way. Paddling boots have a structural sole which bears your weight, rather than neoprene fabric.
neoprene
is best described as closed cell rubber foam - or small cavities formed by gas bubbles in rubber.
Closed cell - there is no gas exchange between bubbles. Tends to be quite water proof.
Eventually, due to use and abuse that closed cell foam can become open cell foam - some of the walls will rupture, and the open cell foam is not that water proof.
Perhaps you could stick those boots in the water, blow some air and see where the bubbles are originating?
Yes, neoprene is waterproof
It is, basically, rubber. Where leakage occurs the neoprene has been broken, either through a tear or from stitching that was not seam-sealed well or became separated.
I have Wet Okole seat covers that supposedly are waterproof. The neoprene itself is indeed waterproof. But the seats have many seams where pieces were sewn together, and these are NOT factory-seam-sealed. If moisture gets on the seat and sits long enough (or is sat on), it finds its way through these seams. Try it for yourself and see, but put a protective layer underneath first.
One of these days (weeks, months…) I should remove those seat covers and paint a thin stripe of AquaSeal or SeamGrip over every seam, on the underside where it doesn’t show. That should prevent any moisture from getting through to the upholstery. A little obsessive, perhaps, but then again it’s cheap insurance.
Good point KM. I am fortunate to live
where I only have to dig my Chotas out a couple of times a year.
Yes, but …
Neoprene has been gradually improved over time. Anything you buy now is almost certainly waterproof. Something that is older may or may not be waterproof. Depends on how old it is. When I began windsurfing (in the dark ages), which was before I began kayaking, neoprene was not completely waterproof. Since the OP said the neoprene was older it may not be the seams. But seam leaks should be examined first.
String, I probably dig mine out
more frequently than you do. It’s a short season down here, but I don’t like cold feet.
This is my third winter with my Quick lace Chota mukluks and they haven’t leaked yet, but if they did, I’d just seal them and would still recommend them. You’d be amazed how many Florida paddlers are wearing Chota mukluks now.
Interesting range of replies
Yes, no, and maybe!
Hmm…
Every post I saw which spoke directly in answer to your question said that neoprene is waterproof. However, a few people pointed out that the seams can leak, one person said that if you walk on the fabric for a long enough time (as is the case with the stocking feet of neoprene waders) it will wear out and leak, and Dr. Disco said that a really long time ago the stuff was not as good, but that what's available now is certainly waterproof, so since your boots don't date back "to the dark ages" ("several years old" is pretty darned new, as neoprene production goes), this would not apply (but I'm skeptical and think that his example is just another case of leaky seams, since neoprene is basically just synthetic "rubber" which by itself is totally impervious to water). So, simply in regard to the whether the fabric is waterproof, that's a unanimous "yes" by my way of thinking. Just find the leaky seam and fix it.
Oh, and since waders came up in discussion, would anyone think that they'd be made from a fabric that is NOT waterproof?
