One of the inherent difficulties of hull design is that there are lots of ways to achieve the same end, but all of the methods will have other affects upon hull performance. Every design is a series of tradeoffs and some designs are catered to a specific condition and cannot be equalled by any other hull design.
For example: Surfskis are long, skinny and tippy, but lots of surf playboats are short and fat (essentially, more along the line of river kayaks). What is going on here is that long and tippy has attributes (hull speed, for example, with a quick response to rudder) that compensate for the lack of being as playful and able to cut in the surf as a short/fat boat. Both are usable in surf, but they fit different styles.
In touring boats, long boats lack that beamy sense of stability (some of the long baidarka’s were so tippy, that they required an accomplished kayaker until the boat reached cruising speed and suddenly become stable and responsive). Turns out, the bifurcated bow on those old baidarkas, which was out of the water in calm seas, was really critical to boat handing when conditions were worse. Hard chines are an adaptation to give the boat better turning performance, especially when the boat is leaned, but they have other affects on the hull as well.
The perfect boat that does everything well is a myth, though that doesn’t stop designers from trying to find it. It is more important to find a hull that matches your skills and paddling style than it is to comply with stated rules for hull design. There are some guidelines:
-ignore LOA (length overall) for hulls, what matters is wetted surface. LOA is only an issue when the seas are in contact with the entire hull and those conditions are pretty rare, though LOA may be a factor in such conditions. If you routinely paddle in rough conditions,
-wetted surface has two features - when flat on the water and when leaned. Most/all hulls have a different wetted surface when leaned, so one needs to consider this when making a choice/test of a hull
-surface above water that is affected by wind (weathercocking) - probably self-explanatory
-forward volume/rocker (affect both wetted surface and how bow performs in waves)
-chines (affect both wetted surface and how boat performs leaned, possibly LOA, depending upon design)
And the list goes on. Swede form? Fish Form? Which is better (long debate about what is probably nothing here is possible). Any choice will affect what is possible with the rest of the hull and some tradeoffs simply will not work for some paddlers.
