What kind of cart should I buy to pull a Wilderness Systems Tarpon 100 thru the sand?
The one with the biggest tires…
Why not make your own…check it out…
I am about to make the following…looks like fun and sure beats spending 100+ dollars!
http://www.kayakforum.com/cgi-bin/Building/index.cgi/noframes/read/107261
http://www.kayakforum.com/cgi-bin/Building/index.cgi/noframes/read/107262
And…a source suggested for wheels:
http://www.northerntool.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=6970&productId=13794&R=13794
Enjoy…
Bob
If you just aren’t up to making one…
…If you just aren’t up to making one…, try the Paddle-Boy kayak cart, with the large wide tires for in the sand. I have the “small” Paddleboy kayak cart with the narrow tires,and it does a fine job on grass and hard surfaces. I hated to spend the money for it, but my 17’10" kayak weighs 58 Lb, and it sure beats hurting my back.
… The one I have with the narrow tires, collapses and fits into my stern hatch compartment. If I had to do it over, I would still buy it again.
… Expensive, but so was my kayak. Using it has kept my boat and back paddling all season.
Happy Paddling!!
Tim built one for ours
he used some 1 inch square metal and welded it. I’ll take a picture of it and post it for you to see. It’s very simple but it worked great. We used it in the sand in Tahoe without much of a problem. Bigger wheels would have been a bit better though.
Lisa
Rolleze is good too
Big fat wheels are the key for rolling over sand.
Seattle Sports
also makes a good model.
CART
thanks for the advice
