I have been kayaking for years but am having increasing difficulty handling my 50-60 pound kayaks. They are wonderful but too heavy. I do some river (light currents), lake, coastal kayaking. Sit in mostly but do own a sit on top ocean kayak. We have a place on a river and often have company who are not yakkers. Looking for some advice on a lighter kayak. 35-45 pound range which tracks well. That is a huge problem with the lighter kayaks. The tracking. Three strokes on one side to keep it going straight. Any advice on type, style or manufacturer.
Weight does not affect tracking. Hull shape does. What sort of kayaks have you tried. Only SOT? The lighter end of the spectrum of kayaks is going to lean more towards composite construction. I have a new Lincoln Isle au Haut that needs a good home and at 17’2" is only 42lbs. I’m not sure that’s what you have in mind though.
https://www.facebook.com/marketplace/item/1981380995514012/
See you on the water,
Marshall Seddon
The River Connection, Inc.
9 W. Market St.
Hyde Park, NY
845-229-0595 main
845-242-4731 mobile
I’m thinking that the OP’s correlating tracking and weight is because the lighter kayaks they tried must have just been shorter.
Especially in the rec boat world, weight is often just a matter of length, and therefore tracking.
Yes I understand that it’s length that determines tracking. It Seems though, in my limited experience, that weight is sometimes saved through making the kayaks shorter. I have four kayaks. Three are sit ins. Only SOT. What I’m looking for is a lighter kayak that tracks well.
Are you looking for a particular length?
One of my kayaks is 14-ft long and weighs 43#. Tracking isn’t an issue; it has a skeg.
Might be useful for us to know the makes and models of what you currently use, so we have a comparison point.
Epic surf ski…sot…tracks well and light weight.
Or a Stellar ski. Epic and Stellar make skis that are kayak like.
If you can find some used wood kayaks they tend to be pretty light even at 16 feet long. Maybe some 13’ish thermo formed kayaks (eddyline/Delta) . Or composite but more money . Stellar makes some light kayaks
Ooh great suggestions. Thank you. I have three perception Carolina kayaks at 50 pounds, and a perception access sit on top. Will check these suggestions out. Thanks for the help.
Epic GPX Ultra at 27 pounds and 12’11 length. Great reviews.
Lightweight Seakayaks:
- Lincoln (as Marshall previously mentioned)
- Sterling (very light, very costly)
- Epic (& others) surf skis (as mentioned by Overstreet), fast touring kayaks (18x)
- Warren Light Craft (is no more)
- TurningPointBoatworks - Joey is now building a composite ‘Petrel Play’ (CLC)
- others???
Build one yourself (very light possibility)
If you can’t (or don’t want to) build it yourself, check out:
Clear Stream Custom Water Craft
http://watercraft.clearstreamwood.com/
(see the ‘Catalog of Designs’ section)
I had a CNC Shrike-R built for me several years ago (26lbs).
Thanks. Great suggestions.
It sounds like we paddle the same type of water and have the same focus on weight and well-behaved hulls.
As Marshall said, tracking is a function of hull shape, not length. For a given hull style, a longer hull will track better, but that doesn’t mean all short boats track poorly. For what you want to do, I’m guessing 14 feet (or even 12) is enough length if the hull tracks reasonably well.
The skis and fast touring kayaks mentioned above are all good boats and light, but not necessarily well-suited to the water you want to paddle. Plus they will be a step up in skill required and are NOT a good loaner boat for visitors with no experience, one of your intended uses.
I tested the Epic GPX, a nice boat. The design and paddling is really good. but I found the deck too low - I had to sit with my legs mostly flat, can be difficult with knee/hip/back problems.
I’ve paddled and like Lincoln kayaks but never owned one. Ditto for Eddyline.
My lightest and best tracking boat is a 13’9" skin on frame Cape Falcon SC-1 (early version of the current F-1), weight about 33 pounds. It has a skegged stern and glides amazingly well, SOF is more durable than you might think.
A pack canoe would do well in the types of water you want to paddle. They can be extremely light, there’s a wide variation in styles and price points.
Folders (e.g. Pakboat Saco, 12.5 ft, 20 pounds) and performance inflatables (e.g. Sea Eagle 393rl, 12’10" 35 pounds) are also an option.
Now that you have a long list of possibles from all the posts here, I suggest looking for used boats here on p-net or the local classifieds. I started out trolling the used listings here, then looking up the boats for sale that seemed interesting - you’ll soon get an idea of what’s out there and what you might want. Often a used boat that you’re not happy with can be resold at cost, sort of a no-cost rental to try things out.
The Current Designs Vision 130 composite might do the trick for you.
I’m 5’6" and 165 lbs and find it to be quite efficient easy (for me) to keep straight and quite maneuverable when put on edge.
I haven’t paddled it on any rivers, and probably won’t, since I usually take my solo canoes on shallow, twisty rivers.
Thank you for this. From the profile of the boat I was a bit concerned about just that issue. At 60 I sometimes have these issues. My sitting antics in a kayak can be interesting to watch!
Thank you for this. From the profile of the boat I was a bit concerned about just that issue. At 60 I sometimes have these issues. My sitting antics in a kayak can be interesting to watch!I tested the Epic GPX, a nice boat. The design and paddling is really good. but I found the deck too low - I had to sit with my legs mostly flat, can be difficult with knee/hip/back problems.
Yes, front deck height is a critical dimension for me. It seems I need at least 13" deck height to be comfortable. One is less locked-in to the boat, but in quiet or moderate water that’s better than legs that go numb after 30 minutes. Canoes have infinite deck height, by the way, which may be one big reason why they’re popular with less-flexible older paddlers…
Remember that durability and cost are inversely proportional to weight. Heavy means inexpensive and indestructible. Light means wonderful handling characteristics but very fragile.
Block coefficient determines tracking
For most this means a fine bow
that talers gradually from the widest point
I have had a oack canoe for 12 years. Its a tripping model at 23 lbs
Most would not take it in the ocean but it handles big waves well
Its been repeated overnight trips on the Gulf of Mexico and Lake Superior
Being open even with a spray cover it wont handle three foot dumping waves but anything below that is fine
You paddle from a sit on the bottom position with a double blade
Check out Placid Boatworks Shadow.
16 feet. 22 lbs
IIRC 22 inch wide waterline
There was a least one mention of folding kayaks – the lightest boats are the skin on frame type, whether commercial folding models or hand-built replicas of traditional Greenland kayaks with steam bent wood frames and urethane-coated fabric “skins”. I’m 8 years older than you so I can totally relate to the yearning for kayaks that are not painful to wrangle.
If your budget can handle it ($3000 to $4000) the Trak folding kayaks are amazing – their 16.5’ model 2.0 sea kayak looks and feel like a hardshell and sets up in 10 minutes but only weighs 42 pounds. It’s fully sea worthy and, as an added bonus for those of us who are retired and have the freedom to travel, can be transported as checked luggage on airlines or carried in the trunk of a rental car or small motorhome. The company has what they call “Trak Pilots” who are a network of competent paddlers around the country who own Traks and who can be contacted to meet prospective buyers for test demos and/or to get new owners oriented with their boats. I met one of them last month with his client on a local waterway. Was extremely impressed with the Trak kayaks themselves – my first opportunity to see them on the water in person. True objects of desire. The Traks also do something no other kayak can do: the frame has hydraulic extenders so that with the push of a button you can change the rocker of the keel to alter performance to suit conditions.
Though I have one hardshell kayak (a 44 pound 15’ Venture Easky LV) the rest of my personal fleet is folding kayaks including a 37 pound 15’ 7" Feathercraft Wisper and a 27 pound 13’ 6" Pakboat Quest (both capable coastal open water boats) and a custom buiklt woodframed rigid skin on frame that is 18’ long but only weighs 31 pounds. It’s very fast, tracks like an arrow and handles rough water very well. Surprisingly stable for a boat only 21" wide but It can be rolled back up easily, though I have not had enough practice to really do that reliably.
I also have a Pakboat Puffin solo (an older version of the Saco that Carldelo above mentioned) a 12’ sit inside kayak that only weighs 20 pounds. It’s not really a boat I would take far from shore, however, though it’s OK for rivers and sheltered bays. Took it with me on vacation to England last year and did not have to pay any excess baggage fees.
