Drove past an old Grumman for sale on the way home. Turns out to be a sail rigged 15 ft w…original sail. only item missing is the mast. Google was no help.
Any ideas…or any laying around in your yard???
You can make one.
If I only had a brain…
The only true dimension I’ve been able to confirm is the diameter. I can measure foot but need idea of clearance spec’d Being a Gunter rig it appears to be a very short mast.
Any thoughts on how to size?
If you can find a diagram like this, and you know one of the dimensions (like the canoe length or length of a spar) you can use that to figure out the other dimensions. https://canoes-for-sale.com/grumman/canoe-sail-grumman-canoe-45-square-foot-lateen-rig-all-original-parts-57323
