Although I have made a workable , side mount, it has its drawbacks. Weight distribution being one. with the mounted motor being forward, it makes tandem seating a bit tight.
Stern mount would solve that problem, but presents 2 more.
- need for control handle extension
OR - making an off motor switch
one work around could be to use paddle as tiller and leave motor straight and simply disconnect battery lead to stop the motor. (Could be dangerous practice).
Intex has a mount for their “boat” which could be made to work on kayak tubes. Only need to buy four of the glue on mounting clips .
Then comes the task of launch - need to wade out to depth so that motor shaft and prop is not making ground contact. Landing - same problem.
am I missing anything?
