Ok, I’m not entirely new to kayaking. I’ve been using an Ocean Kayak Frenzy for about two years. I really need your advice on buying a new sit-on-top kayak. I need one that meets this criteria:
-Stability. I am a paraplegic and am a poor swimmer (I wear a floatation device, of course). I would like the most stably kayak possible.
-Tracking. I would like one that tracks reasonably well.
-Distance. When I go kayaking, I like to stay out for hours and hours, sometimes all day.
Thanks in advance for any advice you can offer!
Good For You!
I don’t know Sit On Tops (SOTs) well but the Frenzy is a short boat relative to other SOT options out there. Longer and straigher keel (bottom middle line) will give more tracking and speed.
I am sure the SOT folks will jump in and give you better suggestions.
Check out
Ocean Kayak’s Prowler, sounds like it might fill your needs, more stable than a Scupper-Pro and faster than a Frenzy (isn’t everything?)
Go to the SOT web site
at http://www.sit-on-topkayaking.com/index.html and post your question on the Forums there. I’d suggest posting on both the “Beginner Questions/Answer” forum and/or the “Kayaking for the Disabled” forum.
I agree with okole on the Scrambler recommendation. Cobra makes several boats that you could look at: Tourer, Navigator, and Maurader. And you might want to give the Heritage Marquesa 14 a look see.
Good Luck!
Scramblers
don’t track particularly well, in my experience. Prowler would be better, or even the Caper (nice and stable).
I sort of liked the Emotion kayaks, too. Take a look at the Exhilarator. Just a thought.
Brian
Robert, you described a Wilderness
Systems Tarpon 160.Very stable, tracks well, has good speed for a SOT. It is 16' long and weighs around 65#.I have owned one for several years and it is my go to boat for salt or rough water. I wish WS would offer it in composite.
Also, I have not paddled or even seen one, but Current Design now has the Kestral. It is 14' and composite material.
Don’t bother
with the new CD boat. I paddled one at the WCSKS. Thought it would be just what I was looking for, it wasn’t. Very uncomfortable seat, not real stable ( it is a SINK hull ) which would require a paddle float for re-entry. All in all very disappointing for me at least.
Kestrel
Was that the Kestrel 140 SOT ? Here is their specs. Can’t find out what it is made with but at 36 lbs. don’t think it is plastic.
14’0" 26" 36 lbs Swede Form Shallow “V”
