I accquired an old pyranha Razor river runner boat. I believe it was made around 96-7. I cant find any specs as to what size or type of sprayskirt to get for this boat. It’s a great little boat to paddle, but definitly needs a skirt.
2c
Cockpit size is listed as 27" x 37.5", but that just does not seem right for WW boat. Especially considering that that boat is 24’’ wide. Probably a typo, should read 17x37.5, typically large deck.
Measure your cockpit externally, then you’ll know what sort deck is required
SnapDragon is one of companies making skirts, here is their deck list
http://snapdragondesign.com/deck-sizing-index/
I believe SD does custom skirts - based on cockpit rim tracings, dimensions, and the placement of butt
Also
I second SD, good skirts. Also Immersion Research makes good WW skirts and are very helpful. If you measure your coaming and call IR they will steer you right.
