I will be traveling to new York from PA this summer and wondering if I need to get ny stickers for my canoe i will take it solo one day with a trolling motor on other but will mostly be used with paddles. I have never taken it out of state and it does have pa registration
should be fine
if you have PA motor boat registration, you should be fine. if its not registered as a motor boat, then you would have to get either a NY or PA motor boat registration.
contact NYDEC if you want to verify that
NY does not require canoes to be
Registered unless motorized I would guess your PA reg would do fine
I see powerboats from other states all the time in the Adirondacks
I thought it would be OK as long as I am not there over a certain amount of time. And it is registered in pa for a motor. I will call to verify though.
leaving
behind the question of is and what is not a canoe
