Well no paddling today, sadly, but I did just spend a little time adjusting the outfitting. I discovered that there is no way my skirt is going to work for this boat. It’s odd, because IR recommends this size skirt for this boat.
Any recommendations for a skirt that doesn’t need to handle whitewater? I’m thinking I might be SOL for actually finding one in stock anywhere, so I’ll be skirtless for a while. Oy.
What size was the skirt that you tried but didn’t fit? If you don’t need anything super water tight, usually going up one size is OK. So a Seals 1.4 should be fine instead of the 1.3 that is called for. I have borrowed a Scorpio a couple of times and probably used one of my skirts (which would have been a 1.4) and I don’t recall it being a problem. I use a 1.7 on my Gemini (which calls for a 1.4) and it works fine.
So it’s the damnedest thing… the IR skirt I have here is their previous XL cockpit size, which is evidently now their L size. According to their tool it should fit this boat. It previously fit my Rockpool and also my Dagger WW boat. It has NO hope of getting on the Scorpio. Not even if Jason Momoa tries it. I measured my new boat to make sure the size is right in IR’s tool, and it is. I’m waiting to hear back from IR, but I suspect this skirt shrunk like a mofo. I haven’t used it in a long while - I was using my Snapdragon skirt that I sadly/stupidly gave away with my Dagger when I sold it this Summer. It’s crazy how much too small this skirt is. It’s also very tight on my body and I am the same size as always. IR confirmed they changed their sizing and that their Large should fit the new boat, but no explanation (yet) as to why the XL does not. I’ve concluded it shrank. By A LOT. It’s just been hanging on a hook in my garage, never machine washed or dried or any weirdness.
I also reached out to Seals and they are telling me the Scorpio LV requires a custom size. Their tool comes back with “*1.3” and evidently the asterisk indicates a kayak requires a custom made skirt. I don’t believe this, though. I think they might no longer make 1.4…? Or their tool is broken? Color me frustrated.
I believe you! Thank you, Marshall. I generally custom order my skirts, though, because I need a stupidly small and short tunnel. This shrunken skirt might work for an 11 year old now… if even. I’ll look at that model and reach out via PM if I think it’ll work for me.
Seals fit tool has some issues. They call for a 1.4 for my Delphin 150 for skirts but 1.7 for cockpit covers. The 1.4 is correct for the skirt AND for the cover. Given that the Delphin and the Scorpio are both P&H RM kayaks I wouldn’t be too surprised to find the coamings were the same. I’ll drop mine down tomorrow & take a couple om measurements. I need to juggle boats around a bit anyway so that’s no problem.
I’ve never had this right and no one has ever called me out for “combing.” The coaming on my Rockpool was quite sharp so nothing ever tried to pop off of it. But the (unknown) size of the cover is just fine for the new boat (after I loosened the bungee a bit). I’m glad I didn’t lose it last night.
I guess I won’t be working on much of anything other than staying upright when I paddle the new kayak tomorrow. Of course it’s always a good idea to practice self rescue in a new vessel, so perhaps I may as well since I’ll be skirtless.
