I just finished reshaping,and reinfircing an entire wood paddle.I now have 2 coats of epoxy on it (except I left the grip bare to oil) and it looks great. Should I put a coat of somthing else on it?
Thanks,Turtle
Epoxy is UV sensitive…
…and it will be damaged by sun exposure if you don’t protect it. You should apply several coats of exterior-grade varnish, which contains UV inhibitors. Paint also protects from UV, but you lose the look of the wood.
