If there are any folks in the group familiar with Lincoln canoes or have access to old Lincoln catalogues, please help id a recent acquisition: 1990 16’5" Lincoln Tandem Canoe, beam 32", 19-13-18, 48 pounds, sure looks and weighs like Kevlar. Thanks in advance.
Lincoln Concord… Measurements need to be taken from the inside of the hull excluding gunwales.
Unless Lincoln changed the design between 1990 and today, it’s not a Concord. The 32 inch beam was measured at the inside of the hull. Already exhausted the internet search including this forum.
They never made another boat in that size range Gunwales can be pulled in or spread out.
Lincoln used to be near here… They seem to have ceased production.
Someone in another forum suggested the Lincoln SRC 16-6, but there a few specs that don’t line up and I can’t find a pic to compare. I have tweaked a few gunwales over the years, but I would never risk pulling in gunwales on a kevlar boat with foam core and ribs from 36 to 32 inches. I have already reached out to Lincoln with no response. But thank-you for your suggestions.
