Can anyone point me to a supplier of canoe portage yoke shoulder pads.
I am looking for the curved ones with a good amount of padding that can be mounted to a aluminum tube thwart with a one bolt connection,( or some sort of clamp for the same.)
Thanks in advance
jack L
Yoke Pad Suppliers
Here’s a couple of sources:
http://www.rutabaga.com/subcategory.asp?sid=3&scid=38
http://www.boundarywaterscatalog.com/browse.cfm/2,136.html
http://www.oakorchardcanoe.com/canoeseats.php
Mad River
Campmor
Mad River BWCA Contoured Yoke Pads
Item Number: 75505
http://www.campmor.com/mad-river-bwca-contoured-yoke-pads.shtml?source=CI&ci_src=14110944&ci_sku=75505WC
http://www.campmor.com/wcsstore/Campmor/static/images/watersports/75505.jpg
Nope
Jack l
Nope
Jack L
Perfect
Just what I am looking for
Many thanks
Jack L
Good pads, but
will you have room for your neck if mounted to a straight thwart? I would think that a curved recess is needed unless you can cantilever the pads towards the bow a few inches.
Bolt Hole
jack,
If you are mounting the pads to a standard aluminum thwart in addition to the neck clearance problem that Jim brought up, there is the issue of the bolt hole weakening the thwart. Two 3/8" bolt holes in alignment thru a thwart would worry me; just a bit too tight on the nut and you are ready to squish the tube and have it fail.
If it was a big oval aluminum thwart in an MichiCraft aluminum canoe, no worries. But the Wenonah or Savage River thwarts, big question mark about making a couple holes.
Bill
You are both right
I just got a e-mail back from John Diller and he is advising using a yoke.
I didn’t want to use a heavy wooden one since I am trying to think “light”
Back to the drawing board !
Jack L
I had a 1974 Sawyer Cruiser
to which I added a Sawyer yoke. The yoke had the pads mounted to a U-shaped piece of aluminum extrusion, and was bolted onto the thwart with two 1/4" bolts as memory serves. I am sure the extrusion made up for the weakness caused by the drilling of the thwart.
