Has anyone changed the pedestal seat in a wenonah prism to a traditional web seat and if so what was involed
Prism seat change
If what you want to do is change the sliding tractor seat to a sliding web seat; just contact Wenonah and order the web seat for a slider. When you get the new web seat, pry off and remove the end caps on one side of the slider tubes. Then unscrew the single phillips screw that holds each tube to the seat frame on the same end you took the caps off. At this point you should be able to slide the tractor seat off. Slide the new web seat on the slider tubes. Tighten down the 2 screws and glue the end caps back on. Shouldn’t take more than 3 minutes.
