Sorry if this is a repeat post. I did a search and didn’t come up with anything but could have sworn I read something on the subject here before.
I just purchased a “rental” boat of the rotomolded variety. What is the best way to remove the paint stenciling. I am thinking a solvent of some sort but wonder with one? Petroleum based would probably work but will it damage the plastic?
As always thank you in advance for the advice and comments.
Ed
i have used sand to
rub it off…takes a little while…less agressive than sand paper…
leave it on??why not???
stencil over it???
lots of choices…
stickers??
Store in a cold place over winter
If you are lucky, it will have “curled” off by spring.
Acetone
I used acetone to remove paint from a ww boat with no damage to the plastic.
If using this solvent be certain to do so outdoors and with good gloves - it will absorb throught the skin and do liver damage.
Common sense first …
Ask the place you bought it from what they use.
Find out the brand and product of the ink/paint used and ask the manufacturer. Also ask the manufacturer of the boat.
Mick
The people where I bought it say
that all that stuff is on there before they get it in the store. I think I will try some solvent on a small inconspicuous (sp?) area and see what happens.
Ed
