I need to replace the caulk line on by Hurrican Phoenix which is ABS plastic. Can I use Silkaflex 505 UV on the ABS plastic or is there a better option?
I would ask Hurricane as there are some recommended products for their ABS.
I repaired a thru hull drain on a a phoenix I believed I used 3M 5200.
I believe there are some products they don’t recommend.
I just heard back from Hurrican and they do use and recommend the Silkaflex 505 UV for the caulk line.
