My newish Eddyline Sitka LT has suffered some unfortunate damage. You can see in the photo where the top is separating a bit from the hull. Obviously I’ve tried to repair it using epoxy but it didn’t hold for very long. Once I strapped it to my roof rack, the seam popped again.
The inside seam is completely intact so there’s no danger of it leaking or anything but I’d like to keep it from getting worse. In my attempted repair, I simply taped off the area with painter’s tape then put on a bead of epoxy.
Is there a better way to go about this or a particular product I should try using? Thanks very much for the help!
