Resealing fabric?
I have a nylon skirt that I would like to get a little more use out of, but the rubberized backing on the porous material is peeling off. Would contact cement make an acceptable replacement for this waterproof backing, or is there a better repair coating? Thanks.
you could apply aquaseal inside
or a spray/wash on DWR onto the OUTside…
i would personally get another skirt and hold the older one as a back up…
r
No
contact cerement would not perform well, and the solvents would very likely damage the nylon.
Try some Poly seam seal
