rudder cable replacement
The rudder cable for my perception sole has rusted thru. Where can I find a replacement. It goes with the smart track rudder system.
Rudder Cable
I usually will go to a marine supply store and buy the stainless steel leader material that is approx. 1/16" thick, with as many strands as possible for flexibility, along with the crimps needed for the job. Also, eBay will sometimes have the SS cable you need. I always buy more than is needed to have spare cable on hand.
http://tinyurl.com/yl9sqb
A lot of local hardwares carry it.
It is just standard stainless steel aircraft control cable. Used for a lot of other things. Quite common really.
Look for the older style and better stocked hardwares. Take a piece with you as it may help.
Mick
Why not buy a new OEM one?
http://www.smart-tracker.com/index.htm
