Sea/touring kayak help for those of tall and big foot persuasion
I’m 6’6", 210lbs, with 13" feet.
I’m out in central WA, with nothing nearby for trying stuff out. Nearest is ~3.5hr drive to Seattle area, but would want some idea before making the trip, and having to buy a roof rack to fit.
I got my first touring kayak for a steal in the past month (couldn’t pass up over using my neighbor’s rec kayak), a 17’ Tempest, but it is too small for me really, so looking to upgrade to something that actually fits more. The Tempest cockpit is really small for me and even after drilling new seat holes and putting it as far back in the pit as I can my shins still scrape trying to get in, and bruise to hell, when I rolled last week, on exit. My feet are currently bunched up cocked to fit at all.
Googling hasn’t been too helpful on what I woulda thought would be a pretty common list :confused: . So does anyone have recommendations/suggestions on sea/touring kayak that will fit?
budget: ~2-3k preferably, but absolutely good getting word on pricier ones to save for if need be
thanks in advance all!
There must be a typo somewhere, because at 6"6" and 110lbs you would be quite unusually proportioned.
A few you might look at;
(I expect he hit the 1 instead of the 2 on the key board. ) 6.5 feet tall and 110 pounds seems like a VERY thin man. In fact 220 at 6’ 6" is still rather thin. I am 5.6 and I weigh 185, so I can’t imagine I am 75 pounds heavier then the new member.
lmao, thanks for the catch there. Yes typo, 210lbs
hah, actually trying to cut back to 195 atm as let myself get carried away with local bakery a block away…
But yea, tall and lanky. Working on getting into shape to actually be able to do some day trips and also be able to reliably self rescue as I was having trouble practicing the other day.
oo! hadn’t heard of either of these before, thanks!
I have size 14 feet under my 6-1 at 160 lb’s so I appreciate your foot room needs. I paddle a Valley Q boat with just the right amount of toe room for me. I removed the foot braces and put foam on the cockpit side of the front bulkhead for more leg room. That provided some more foot room with my heels now at center line’s height. I have the freedom for feet together or splayed when I need some firm contact. I also paddle with fairly low volume water shoes from NRS. Other used boats that might suit would be an NDK Explorer, Valley Argonaut, P&H models promoted as high volume. Any boat that offers more room comes with more front volume and windage. My Q sits a bit high unless some gear or ballast are in the front hatch.
When you say “Valley Q” is Q the model name? I wasn’t seeing any when I googled just now. I assume older, but trying to find measurements to compare against current offerings or used stuff in my state.
I’m 6’5 / 220# and finding a kayak that truly fits has always been an issue. Cockpit length is the usual problem.
Valley Canoe Products (VCP) Qajariaq, or Q boat for short.
ah, thx!
Have you looked at WS Tempests? A 180 came closest to fitting me except it was too big.
I didn’t know the had a 180
I’ve got their 170 right now
Another data point, an Epic 18X cockpit length may be OK but shoe size 12 max. And watch out for paddling shoes that feature toe bumpers and heel spoilers that make your foot even longer.
PM sent
Here is a resoonse i made to a prior thread with a similar subject:
I don’t know the friend’s shoe size. Definitely larger than my 11s.
He currently paddles an Epic 18x
At 6’5" 215, with a size 14, I feel your pain. That said, I’ve been overall pretty comfortable in my Sitka XT. I added some hip pads since I’m more tall than big, but it’s worth adding to the list.
I am your size plus 10 lbs. I may have to try one of those.
I did end up grabbing a Sitka XT, thanks all for all the suggestions.
This thing ended up being even roomier than I was expecting. I too needed hip pads.
You made a good choice, I have one I’m selling only because it is made for folks of your height. I’m only 5-11 and I got it primarily because of the long cockpit opening that made it easy for me to get my right leg in, I have a new hip joint on that leg.
I have since discovered I can get back into cockpits the size I used to have.
Enjoy the Stika XT, they are beautiful made and ridiculously stable.
Mine
