Any opinions on fitting a skeg to a rounded hull? For obvious reasons, of course. Will it help this little pup track better?
Thanx,
T
yes
a skeg will add tracking to the stern, a rudder, tracking and turning.
what boat?
steve
Necky Gannet
Is 13’ rec kayak that comes standard with a skeg.
I keep one for friends to paddle and they tell me it makes a big difference.
It’s basicaly a flat piece of aluminum which pivots verticaly between two aluminum L brackets. There is a cord to pull it up and gravity drops it when the cord is released.
This is the Santa Cruz but it has the same skeg
http://www.necky.com/santacruze.htm
Might even be the same boat with a hatch?
I would think that it would be fairly easy to make your own.
Here is an example
http://www.dimensionkayak.com/en/r5.html
I have this bungeed in place skeg on my R5 that can be flipped over when not needed. Tracking improved dramatically with use of this skeg.
