I’ve just purhased a tandem kayak that lets you slide the front seat back and use solo. It also has a second slidelock foot brace track so that you can move the foot braces back and use them. Is there a trick to taking the braces off the track so I can put them on the rear track?
Tracks
– Last Updated: May-30-07 8:45 AM EST –
If the pedals can't slide off one end while you're holding the latch, there may be a end cap on the track that you have to remove. I can't be more specific without seeing them.
because you said slidelock i am thinking
it is a wildy boat…
if it is then yes there is a cap at the close end…a bugger to pull off…a screwdriver helps the first couple of times…
