Any recommendations on where to get a small tube of gel-coat repair goo? I don’t need a quart sized can. Plus any tips on the application and finishing process. Thanks in advance.
Might want to show pics. For thin cracks some folks use Captain Tolley’s…and manufacturers often say “do nothing”. Just FYI clear Gorilla tape over a boo-boo will keep it waterproof forever too
I’m not sure of best place to buy gelcoat. I’d try a local marina. I think Hemlock Canoe or Northstar may sell it but not sure it can be shipped.
I’m no expert but I just cleaned up the damaged area to remove any loose gelcoat then mixed a little and applied it and covered with Glad wrap held in place with tape. Better to use too little and do it 2-3 times than too much. The finish may be good enough with just the Glad wrap or you can sand and polish to make it as shiny as you like.
is that your go-to sorta like peel-ply?
Northstar makes a kit that has 1/4 pint gel coat, sandpaper, masking material, instructions, etc. for $45.
West Marine sells it also. Unfortunately it isn’t sold in really small quantities, but you can mix a bit at a time and it lasts quite a while.
Be aware that even if you have a white hull, white gelcoat is likely a more brilliant white than your boat. Color matching is an art.
Then again, it’s a boat, not a fine piece of furniture or the ceiling of the Sistine Chapel.
