I have a Qcc400x with a smartrack rudder there is a 5in pin that goes through the rudder and the brackett. I just had mine drop out as I was headed back home today. Is there a good way to keep this from happening.
rudder pin
Hmm. I had that happen a couple weeks also.
I just went to Home Depot, and got a threaded
rod with some washers and lock nuts. That seems
to do the trick. Never did get on the water, though,
the wind never dropped below 25 kts.
. Greg
rudder
That sound like a great idea! Off to Home Depot tommorrow after I get out of work.
Thanks for the tip
Barry
Instructions,
on a SmartTrack system that I purchased to retrofit a boat indicate that you should put a slight bend in the pin, that will keep it from slipping out.
HEX
