I’m looking a maneuverable, relatively light solo canoe. This will be my first solo, and I don’t have a lot of experience with the models and manufacturers.
Any suggestions on a good canoe that fits the bill?
I’m hoping to find a used deal online but I’m not ruling out new if that’s the only option–
Also would love to know of any good sights that might have a good line on classifieds for solos (other than p.com of course).
What is your budget first off? How light and what length were you thinking? What kind of usage will it get (day paddles on calm water, extended river trips, etc.)?
Are you looking for what they call a pack canoe?
I converted a shorter 14’7” tandem into a solo and that has suited my needs very well. I paddle it with a double bladed kayak paddle.
I had a Dandy. Marvelous cruiser Not slow but the hull is constant flare so its wide at the paddling station
It is an rarly Freestyle boat and turns but there are turnier boats out there
Again excels at lake cruisibg and many have installed a sailing rig
600 is a bit high
I paid 700 for mine in 1999
Its a 30 year or more old boat
I think a Bell Merlin II would suit your size and aims very well. A Merlin II in “white gold” construction would be right at the upper end of your weight criteria. A “black gold” version would be lighter.
At your height and weight, the Flashfire would be too small. Not enough room to move around in the boat and not enough reserve for equipment. A Wildfire would be an excellent choice, both size wise and for your intended usage. For the usage that you describe, you’d likely want a boat that has modest rocker. 1 1/2" give or take would be the right range. Yes, you can heel and turn a flatter keel-line boat and I do recommend learning how to heel but you did list maneuverability as a priority specification.
Another boat to add to you shopping list would be a Savage River Illusion though finding a used one may be tough.
I have a sneaking suspicion I may be entering into a “canoe phase” where this boat may be the first of more to come.
Maybe the next will be one with more rocker.
