I have a new SOT(11.5 ft, 45 lbs.) that is fairly new and now has a leak. I found a tiny hole on the bottom of the bow. Can this be fixed and if so has anyone had luck with the fix lasting? thanks
three letters
RTV!!!
Radio-Television?
Check Ocean Kayak Site
They have some good tips under maintence section.
If its really new
and the hole was not caused by something you did, it might be worth a trip to the place you bought it, or a call to the manufacturer to see if you could talk your way into a warranty repair or replacement.
