Splitrock, Osprey, Mist, Prism? Which?
Interesting, I wonder what a Rendezvous
would weigh in an ultralight layup. Any idea?
I’m thinking that the length of the Vagabond is about right and it has a lower profile than even the Rapidfire — so low windage, some rocker so a bit more maneuverable if perhaps a little slower than the Packer or Prism, less wetted surface than the Prism, and comes with that adjustable seat I like so much (same one I have in my Solo Plus). Seems like most people kind of dismiss the Vagabond – why is that?
because its the all purpose sloth
You will endure but not shine. I think its more for folk that dont worry about things like boat dimensions!
To even mention RapidFire with Vagabond is odd… Vag may be an all purpose boat but hardly exciting to anyone who has exposure to other solo boats.
That said if you can get a bargain on it, why worry? You will find out soon enough if it “floats your boat”
pretty effortless (NM)
The Vagabond is not bad IMO
– Last Updated: Nov-08-10 7:38 AM EST –
I've done a fair bit of paddling with a guy who owns one and usually paddles it with a double-bladed paddle.
We have traded off boats some. It may not be exciting if you want to heel and spin the boat a lot, but it doesn't sound like that is your plan.
"Wind and waves" is the kicker. When the wind comes up, you would like to have a boat with less sticking up out of the water to catch the wind. But with wind often comes waves, especially on big lakes, and then you want freeboard to keep the water out and for seaworthiness. I think to some extent, your choice will depend on your comfort level paddling in waves.
A boat with a downriver racing heritage might make sense. These tend to have more depth to shed water going through wave trains, but still have good speed. The Wenonah Jensen designed C1W was mentioned. Another is the Wenonah Advantage, which Wenonah will still make special order.
You might take a look at the Clipper Freedom. This is a fast boat, but it might not have enough depth for you to feel comfortable in waves. It has a sliding tractor seat that can be easily adjusted to one of three different levels. A tractor seat isn't the greatest for kneeling, but if you really wanted to do that, you could probably easily fit a webbed seat to the frame.
I agree with Tommy about the Osprey. That boat is really a pleasure to paddle at a very nice cruising speed and is very seaworthy. The Prism is a fast boat, but fairly deep, and with perhaps more volume than you require. The Rendezvous is a pretty large volume boat with more rocker than desirable for the use you describe.
You said you paddled the Wenonah Voyager. I assume you ruled it out. It certainly is a fast boat, but perhaps more boat than you would want for day trips. I have also experienced its tendency to lock onto a side wind, but I haven't paddled it enough to "figure it out".
The usual suspects
Interesting that the Advantage keeps coming up. I looked at it and the Freedom both and was fairly keen, but then I paddled the Rendezvous and felt that wonderful “rockered” feel and how it seemed to shoot forward off the mark and of course I had paddled the Spitfire and Rapidfire, which also have rocker, so I said to myself, maybe these long sharp racers are too much for me and then I really experimented with the Voyager and it seemed to confirm that.
The Summersong is another boat I really like the look of, but is a tad on the heavy side for me and getting it here presents a problem.
The other thing about the Freedom and Advantage is that “leaning the wrong way,” thing, as I call it, to make a turn. I guess that could be learned, but old habits die hard. I’m much more of a brace-in-a-turn kind of guy.
wow.
The Osprey sounds like a great design.
Vagabond
You have a difficult compromise to make, between nice cruising ability and good seaworthiness. I used to have a Royalex Vagabond, and in spite of all the lackluster comments you see about that boat, it was surprisingly nice for flatwater cruising. A composite Vagabond would be a quicker due to sharper entry lines and all the other good stuff that goes with a composite boat (for example, oil-canning in the Royalex Vagabond is pretty severe), and will have better manuverability than the Royalex version too, (the Royalex version is half a foot shorter but that is cancelled-out by the fact that it has zero rocker. The rocker of the composite version should help a lot for turning ability). So, I feel that a composite Vagabond would make a good cruising boat. However, the way that it handles in waves complicates the issue. Like most (all?) Wenonah boats, the Vagabond’s widest point occupies mere inches of the overall length at center, so there’s a steady, straight-line taper occupying the entire forward and rearward halves. Also like most Wenonahs, the sides ov the Vagabond are vertical at the locations where most other canoes have flare. I found that my old Vagabond would slice right through waves, and therefore it would take on water for the slightest excuse (and I weigh less than 165# so the boat was carrying a light load). The boat I replaced it with, a Bell Merlin II, seems narrower overall, but is quite a bit wider within the center of the forward one-third and the center of the rear one-third (that became obvious when it wouldn’t even come close to fitting on the same storage rack that previously held the Vagabond). Therefore, in spite of being narrower “overall”, the extra width “where it counts”, along with a bit of flare, makes the Merlin II ride waves considerably better (I haven’t pushed the boat’s limits in waves because I have another boat that truly shines in strong wind and big waves. If it weren’t for that, I’d know more about how the Merlin II handles in waves). Based on my experience with the Vagabond, I’m pretty confident in suggesting that if you plan to paddle in choppy conditions and want a Wenonah with virtually no flare and a straight-line taper from mid-point to each end, I think you’ll need one with a lot more volume than the Vagabond or you’ll be submarine-ing through a lot of waves. If the waves you encounter aren’t that big, I think a Vagabond would be a really nice choice.
rendezvous and prism
Eric Nyre’s inventory page –
http://www.canoecolorado.com/inventory/canoe/
– suggests that a Kevlar Rendezvous weighs 42 to 47 pounds. I have paddled one and enjoyed the nimbleness, but it’s a very big boat relative to what I usually paddle. I wouldn’t want one for anything but big trips on big rivers.
I paddled a Prism for a few days and didn’t like it. It is also very big, but it lacks the nice feel of the Rendezvous. Didn’t seem particularly fast, wasn’t pretty – nothing to recommend it, except that it’s a canoe (which might well be enough, in the right circumstances).
If you like the RapidFire, why not get it? If you can afford the boat, you can afford the shipping. Mine (with a kneeling seat) is a lot of fun to paddle.
Mark
Hey flickr friend!
I really appreciate your comments on the Vagabond. I guess I do need to decide “the worst” conditions I might find myself in. So far when I get waves larger than 2 feet or so, I move either to quieter bays, or off the lake as soon as possible. I have been in larger waves but not on purpose!
I’m not sure exactly how to measure wave height, is it from trough to peak? In that case I have not been out in greater than 3 foot waves in a canoe, only in skiffs or power boats. I have probably been in 3 foot waves in a tandem kayak on the ocean. Most of my paddling will be on medium sized lakes so I think something that can handle 2 to 2 and a half foot waves is sufficient. hard to estimate wave heights from memory…
Perhaps the Vagabond with a spray skirt would be all I need. I recognize it is not a glamorous hull, but on the other hand, I personally think it has nicer lines than the Prism.
And cost and weight are a factor, despite what we might wish!
Interesting comments on the Prism
I kind of wondered that about the Prism.
re the Rapidfire. Well, it requires a trip to the states to pick up and adding the shipping cost to the premium price of the boat is causing me hesitation. Same shipping and premium price issues for the Opsrey. I can get either, but I have to know it is going to be a vastly superior boat.
I have local dealers for Wenonah, Old Town, Clipper, and Bluewater, and Hellman – well and Mad River too, but I don’t think Hellman and Mad River have a boat I would like. If possible I would like to order from Wenonah, Bluewater, or Clipper, but I have to say that from what I have gathered so far in my research, what I really want is a boat from one of the other manufacturers.
Of the ones on my original list, the Splitrock and Mist are still attractive, the Packer from Clipper, and from Wenonah I have dropped the Prism and added the Advantage, Argosy, Rendezvous, and Vagabond. I just don’t hear that many good things about the Prism. I do know someone who might let me try out his.
My Solo Plus is basically a fat Prism – at least that is how I think of it!
Splitrock, Prism, Osprey re RapidFire
– Last Updated: Nov-09-10 2:14 PM EST –
Casual purview of the numbers indicates the Prism and SplitRock are likely to be similar hulls. Both 16.5ft OAL and 26" at rails and waterline. Prism is 30" wide, no max beam given for SR and both have minimal rocker.
Most figure Bell's Magic in Black/Gold is the best in class of this dimension range; ~ 16'X30" w/ scant rocker. All three respond best to seated paddlers with bent paddles. Those long, skinny bows do not draw to a Duffek
Osprey is 15' X30" max with heroic, differential rocker. It will be much more controllable in moving water than any of the above; the closest hull to it might be Bell's Merlin II; 15'X29". Both respond well to sitting paddlers with bents and kneeling paddlers with straight blade sticks. Both are the best in class solo trippers, with advantages over Mist, etc.
RapidFire is another beast entirely; 15'X 27.5" width with significant rocker. Most paddlers are quite happy sitting low with double blade sticks. Beware conversion to a kneeling boat, M Handy has a gyroscope inserted where the sun don't shine; an exceptional athlete!
Other significantly sub 30" solo tripping hulls include Colden's Vagabond, 27.5" and Nomad 28.5", Hemlock's Kestrel 27.5" and Peregrine 28.5".
In terms of build quality, the Osprey can be had with a similar infused hull with integral fiber over foam rails as the RapidFire, but first you need to decide what your stance in the boat will be.
Let’s say sitting with a double + single
– Last Updated: Nov-09-10 4:21 PM EST –
and let's leave out kneeling for now. If I am just going to be sitting and paddling with a double Aleut blade across the rough stuff, and using a single blade for cruising along the shoreline on the other side. I might occasionally encounter waves up to 3 feet but rarely, and I am mostly doing day trips.
And lets say I have to choose between the Splitrock,the Advantage (I've added that back to my list after listening to John over on the CCR board)and the Osprey, say, with a possible glance at the Argosy and Clipper Packer.
Just for argument sake, lets say the Rapidfire, Magic, Summersong, and the Colden boats are off the table.
then what do I pick?
x the advantage
I would eliminate the Advantage if you are going to be out in rough conditions.
Now
You’re playing games. I’m out.
I am tired!
Pick one. If you dont like it…sell it! After a while your mind just plays tricks.
I meant no disrespect or offence
– Last Updated: Nov-10-10 2:14 AM EST –
I apologize if it seems like I am playing games. In fact I would like very much to order a canoe from Placid Boat Works or Colden or Sawyer or Bell but it is difficult or impossible to arrange to have these boats sent to Vancouver Island.
Swift and Souris River have said they are willing to and there are dealers on the Island for Wenonah, Bluewater, and Clipper.
So since I am limited, is some respects, to these companies my task is to decide which of their boats will fit my need as originally expressed.
I have appreciated everyone's input so far and am sorry if I am taxing your patience.
I don’t think its you
at all but maybe if you go with your gut and we all shut up that would be best. Remember boats are not forever and you have to work with what you can get! You can’t sell your wife(husband) but you can sell a boat.
(I was about to suggest a Grumman 129 as workable…)
Maybe Wenonah Canak?
http://www.wenonah.com/products/template/product_detail.php?IID=245
If I could try them out, my gut would
inform me instantly I’m sure. Looking at a few pictures and dimensions leaves my gut scratching it’s…ok I guess I shouldn’t mix metaphors.
Anyway, I appreciate everyone’s input and suggestions. If anyone else would like to comment I will be grateful but I understand long threads can get tedious.
Peace and happy paddling to all…
Interesting, but not sure I need all
that deck. Have you paddled it?
