I need to swap out a backband on a Boreal Ellesmere. Didn’t know what backbands might work best in a boat where the seat is mounted quite far back in the cockpit, not allowing much space between the backband and the cockpit rim.
Try usin minicell foam shaped to fit?
– Last Updated: Sep-11-06 9:51 PM EST –
2nd that!!
Mine is still a work in progress and I find I shave a fraction more each time I go out for a long paddle, but even as a rough ‘block of foam’ it worked better than any backband I’ve tried. That’s just my personal taste, but it’s a very inexpensive option to experiment with.
Lyn
Where
– Last Updated: Sep-11-06 10:26 PM EST –
Where do you buy a block of minicell?
Never mind. Found it at NRS.
How do you shave minicell?
With a Bic disposable
Not really - Use a Stanley Shureform tool, then sandpaper. I like drywall screen because it clears dust easily. And wear a dust mask for large jobs! Dragonskin works well too - but is impossible to find in big box hardware stores. NRS sells it.
and don’t shave your face with a Shureform.
