As a vertically challenged person, I would like to shorten a pair of NRS Black Rock paddling pants made with Goretex-type fabric. The reinforced knees fall below my knees, so I need to take 1.5-2" out of each leg, between the crotch and the reinforced knees. Cutting and stitching seems pretty straightforward, but where can I secure the waterproofing tape applied to the inside of the seams? Anyone have experience applying this tape, or performing this kind of mod?
Custom shop
Heres a link to a shop that customizes outdoor gear. Applying the sealing tape requires a apecial hot air device I believe.
http://www.specialtyoutdoors.com
Good luck!
sources for tape
Here are a couple of places that list iron-on tape for home use:
http://www.questoutfitters.com/miscelaneous2.htm#SEAM SEALER
http://www.integraonline.com/~wyeastfabrics.com/cgi-bin/store/perlshop.cgi?ACTION=thispage&thispage=waterproofbreathable.html&ORDER_ID=700490492
Both sites give brief information about using the iron-on seamsealing tape and would probably give you more info if you contact them. Some people use liquid seam sealer (like you would use on a tent) for home sewing with waterproof-breathables.
My wife, who sews…
…most of my paddling gear, uses quest.
