Do you know any sea kayaks that employ the toe pilot rudder control as in Smart Track System? QCC is one. Any others?
Current Designs
I think that is what is in my Titian as you turn the rudder with your toes. The footpegs remain where you set them.
Prijon and Venture (special order)
use the same type Weed mentioned.
Get what ever boat you want
that has a rudder, and install the toe control that Pat makes at Onno Paddle. If the ice ever melts here in N. Wisconsin I’ll be able to try out the one I installed in my QCC-700. Installation is easy!
Prijon
With the Prijon, you need to adjust the elastic when you adjust the pegs to fit a different paddler. It’s a pain. Do you do that with Smart Track?
