I ran across an 87 solitude, white gelcoat with silver aluminum trim. The seller is a little vague on some issues but th eprice is appealing. Im not sure w3hat lay up it is, could be a 30-60 pound range. Main question, glassed in floor slats and no seating? what is missing?
The pedestal seat
on early models the slats were wood and the seat rails screwed into the vertically set 1 x 4’s. On later models the aluminum pedestal frame is glassed onto the hull bottom. You need the pedestal seat, which a Wenonah dealer can supply.
