to the mix
From my experience, "bite" goes like this:
Cyprus->Shuna->Ikelos
The choice of blade is dependent on your level of fitness and paddling style. Most people will find Cyprus or Shuna adequate.
Try before you buy would be the best advice, but that is easier said than done in most cases.
shoulder issue I’m 5’10" not in great shape but strong. My shoulders are strong - but they hurt all the time. Right shoulder surgery twice. Most of my paddling power comes from my body, not my arms or shoulders. Paddling generally does not cause me a lot of additional shoulder pain but it may be because I tend to paddle on the right side which means my worst shoulder is always low - ie. not stressed. Kayak will be a whole nother issue.
My personality is such that I often bite off more than I can chew - or so my wife tells me.
You need a smaller size blade, as well as run don't walk to instruction in the forward stroke with the double blade so that you are taking the strain as correctly in a kayak as it seems you are in the canoe.
I have both… …both are BS now. The Cypress in 210 and the Ikelos in 205. I used to have an Ikelos SS in 210 and it was usually too much of a good thing. The Cypress was my paddle of choice.
I replaced the Ikelos SS with the BS and went shorter. Upped my cadence a touch and feels much more comfy. It’s still a pretty big stick but I am preferring it now over the Cypress.
Is there some reason … … you are choosing between those two paddles? My wife has a Cyprus and I have used it. It is a very good paddle. You cannot go wrong by choosing it. But there are other paddles out there. In particular you can talk to Patrick at ONNO paddles. His paddles are top of the line, very light, and adjustable (both feather and length). He is very knowledgeable and can talk to you about what is appropriate and why. Give him a try.
A word of caution … … Choosing the wrong paddle can be a painful lesson.
Several years ago decided I wanted more speed. So I did some research, then went off to a local paddle shop that had a great end of season sale on Werner paddles. I had a different brand paddle that was close to a Cyprus. So I looked at the Shuna and Ikelos. After trying both, the person helping me proclaimed Ikelos, like the sorting hat in Harry Potter.
The first real paddle a week later, and I found my stoke had developed a pronounced slice, like my golf game. After reading and paddling, the slice only got worse: if no correction, I’d end up where I started, like an errant torpedo.
So one day I went out determined to power through this, and ended up with one extremely sore shoulder. If left alone for a week it would feel a bit better, but then any physical activity would aggravate it. A doctor visit and ultrasound later, I found out the damage I had caused. I opted for therapy over surgery, and after a while it got better. But I can’t lift weights, and it won’t take much to set it off again. I had to give up paddling for nearly 2 years.
For what it’s worth, get some very good advice. The folks I bought my new boat from spent as much time with me on the paddle as the boat.
Lesson A paddle with a larger blade, other things being equal, requires a better stroke. A poor stroke with inadequate rotation is a sure way to shoulder problems. A quality forward stroke is something that develops over time and practice with good instruction. Someone starting out should definitely go with a smaller blade. It will not disadvantage you and is much less likely to create shoulder problems. Size is important but not in the usual way. Go smaller and learn good technique. Then add a larger blade when you need it.
There’s got to be shops or at least groups in your area. Beg, borrow, con, whatever, to get your hands on at least one of them. You’ll get a lot more sense of what will fit you.
For some people, paddle is extremely personal. The wrong one is money thrown away.
I had tried one well-regarded paddle and hated it. I’m glad I had the option of returning it.
just get the Cyprus seriously, it’s the more widespread for good reasons, the Ikelos is great for when you’re feeling really macho, otherwise it’s just a beast of a blade, un-necessarily huge and taxing.
wait, wait, i feel it coming… the next poster is going to tell you to get with the times, go native and get your GP thing going, it’s far superior to these primitive Werner tools for those who get it.
Make sure you get the right lenght These paddles have relatively short blades, so a shorter overall length compared to some others may be necessary. Make sure you have the option to try/exchange if you get the wrong one. Plus your style/conditions change - that’s why an extendable length shaft is a very good thing but Werner does not offer one as far as I know. Also consider the AT Xception range - different feel from the Werners. I have not paddled the Epic relaxed tour model, but the Active tour is nice (but quite powerful - may or may not need that, looks like you won’t).
Bent or straight shaft is a personal choice too. I have tried the bent and straight shaft Cypress and prefer the bent shaft version. That said, I like the feel of the blade in the water of the Lendal Kinetic Tour even better (but wish their ferulle offered a no-tool option like the on the Werners or even better, adjustable length like on the Epics)…
If you want mainly to travel forward, why not consider a wing? Something comparable to an Epic mid-wing or a small-mid, when used properly, will probably give you a better turn of speed for your efforts.
Shuna vs Cyprus vs Ikelos Cyprus and Shuna have exactly the same blade size but since Shuna lacks buoyancy (in the blades) it feels different in the water.
I have tried Shuna and own a Cyprus and Ikelos. I would recommend the Cyprus as a great allrounder, but Shuna is a great choice if price is a factor. Ikelos + heavily loaded kayak + long distances in tough weather + tight schedule equals pain, but Ikelos is great for shorter training sessions and roll practice.
Onno.
Even though my shoulders are shot I can wield a very big graphite Zaveral blade for hours on end paddling a loaded tripping canoe because I use my body, not my arms, to paddle. Onno paddles are made with the same shaft that Zaveral uses so that will seem familiar. We'll see. Thanks for all the good input.
Cyprus vs Ikelos You are correct the only difference between these paddles is the blade size. The majority of people prefer the mid-size blade of the Cyprus. If you are a larger person who is well conditioned or your do more manuevering strokes, you may prefer the Ikelos. I find that paddling longer distances with the Ikelos puts strain on my shoulders.
Love the Onno I managed to get out for few hours today on some quiet water. I like this paddle a lot. It is light, of course, very quiet in the water and smooth. But it is also very powerful. I find that it feels great no matter whether I am paddling aggressively or gently. The best thing is I can change the length and the feather angle in an instant. Great help for a guy like me trying to transfer 30 years of open boat paddling to Kayaking. I know there are many good paddles out there, but I will admit it feels good to support a small business man that make a quality product.
