The garbage theory of the Aleut ridge
Here’s a theory similar to grandma’s roast.
Once upon a time, many years ago, Aleut paddle makers had a lot of time on their hands. They experimented with lots of sizes, shapes and even goofy appendages. One day, a guy put a ridge down one side of a paddle and declared that it produced some beneficial paddling effect. His buddies tried it out, thought it was worthless, and tossed all his goofy ridge paddles onto the midden mound (garbage heap).
Now guess where archaeologists find most of their ancient stuff – midden mounds.
So some 19th century archeologists discover a few relics of these ridged paddles. They draw pictures of them. They take pictures with their newly invented Kodaks. Because the ridged paddle relics were so mysterious and sexy, the pictures of them proliferated in books out of proportion to their incidence, along with unsubstantiated performance myths.
Finally, some modern paddle makers, seeking distinctive paddle shape niches, and trying ride the late 20th century wave of aboriginal paddling worship, begin to replicate, talk excitedly about and essentially market the ridged paddle.
As the curtain comes down, the goofy garbage of yore is being bling-blinged via the internet as a sacred relic of paddling performance passed down from ancient sages.
Just a theory. Just a theory.
Concept vs actuality
The stagnation line is not a concept, it is a fact of 3-D fluid flow over an object. It marks the boundary between the flow that goes over one side of the object, vs flow that goes over the other side.
A stagnation line exists on a paddle as it must, because some fluid flows around one side, and some flows around the other. A stagnation point only exists in 2-D flow; flow over a paddle is decidedly 3-D. There is no such thing as a stagnation area. Any intro fluids text should suffice to explain the concept in more detail.
Re: the flutter argument, it’s clear to me that the ridge will reduce flutter, based on my experience in experimental fluid mechanics. No one is saying that a ridge is the only, or even the best way of avoiding flutter - that’s your supposition, I think.
The fact that you’ve only seen a ridge on a cheap Euro paddle, and that racers don’t use paddles with a ridge means nothing, of course. It’s an argument, of course, but not proof of anything, as I think you must admit.
Ask a simple question (that was simply
answered) and you get a p.nut pissing contest! Maybe those Greenlanders weren’t skilled enough to put ridges on their paddles.
Concepts are reality
Of course there are stagnation points in 3D flows. Otherwise there couldn’t be a Kutta condition on an airplane wing.
I agree that if you freeze frame a paddle in the water, there will be a spill line, which you can call the stagnation line. But that line will constantly shift along the face of the blade, and may be crooked, as the paddle moves through the water, unless the paddle is pulled perfectly flush to the water at all points along stagnation/spillage line, which seems literally impossible.
Maybe “stagnation point” or “stagnation area” is the wrong term to describe how a cupped paddle “holds” water better than a flat paddle, but there are experiments that show that. The longer the water is “held” before spilling, the more power the blade has.
My experience is mainly with canoe paddles, but I have paddled with dozens of kayak paddles including GP’s. Many paddles do have a mildly raised dihedral line down the center of the blade; others have a more rounded camber. Many argue this helps helps avoid flutter; others say it does so at the penalty of reducing power (the “held” water). Completely contrary, however, is that there are many flat-faced bent shaft canoe racing blades that don’t have any undue flutter.
However, I have never seen any paddle in all my life that has the very high and sharply defined ridge of the Tuktu Aleutian paddle. That’s not meant to be some sort of statement about my paddle knowledge. Rather, it’s supposed to reflect the complete absence of this supposed performance feature in the minds and designs of competitive paddle makers over the last 60 years.
Hey, that feels pretty good
I think that neither the ancient Aleutian islanders nor the Greenlanders had a strong theoretical knowledge of fluid mechanics or access to nice laminar flow test tanks.
They had sticks and carving tools.
And plenty of free time on winter nights.
So they made paddles and tried them.
Eventually they both got to “hey that feels pretty good", and the respective culture’s standard paddle was set.
Chill
this is getting pretty silly.
Getting way technical
Interesting history, but getting way out there!
Maybe Greenlanders didn’t have any
material to waste.
Re dimensions
Sorry but there is not a stagnation ‘point’ in 3D flow. A cross-section of 3D flow will show a point, but overall on the paddle itself, it is a line. The shifting of the stagnation line you describe is exactly the behavior that causes flutter. I think we’re talking about the same phenomenon, and having a misunderstanding re: terminology, which is understandable for internet discourse. We should really be standing at the blackboard (with a beer?), and all this would be a lot more productive.
One last 11 dimensional point
Because I don’t think we’ll ever be together at a blackboard and I haven’t drunk a beer since the Reagan administration. Sad as it is, the internet is my only current university.
Forget paddles and paddling.
Is a line not composed of points? If so, then any stagnation line is composed of stagnation points.
Consider an egg. Consider it moving through a fluid. This is a 3D space according to Euclid, or 4D according to Einstein, or 11D according to Witten.
Not considering boundary layer effects, what is the stagnation “geometry” on the frontal end of the egg? I don’t think it’s a line. I suggest, asymptotically, it’s a point.
Back to paddles.
I accept the terminology and actuality of a stagnation line on a paddle face.
Much more reluctantly (without empirical proof), I will accept that a symmetrically spilling stagnation line will reduce paddle flutter vis-a-vis some other stagnation line.
What I have real difficulty accepting is that you can “force” this symmetrical spillage by gluing a ridge on a paddle face. Paddle face movements are too complex and changing in 3D and 4D for the spillage to maintain symmetry. (I don’t believe Witten and his 11D supersymmetry.)
And if I had spilled more many decades ago, I might have finished majoring in physics instead of Budweiser.
I’ve Got it!
The clever Aleuts put the ridge there for extra weight. The paddle then served double duty as fish bat to finish off their prey.
Eh?
Eh?
Give it to me, paddle brothers. You know I'm right.
Geez!
It’s 6:50 in the morning. I just read this whole thread and now I’m ready for a beer.
The ancients made stuff with the materials they had. It was usually conservative and practical by design. If we have examples to study them someone obviously went through the trouble. There was a reason and as explained, it just works. I have one and have used several others and they do work. Plain and simple. Why spend the energy over analyzing this?
Yes
Re: the egg, you are correct, in the same way that on a baseball or the nose of a jet, there is a single stagnation point at the front of the body.
On the wing of the jet, however, there will be a stagnation line down the leading edge, and another pinned to the trailing edge (the Kutta condition, as you mentioned). The difference between the two situations is obviously the aspect ratio of the body as it is presented to the flow (AR = weight/height).
An egg, ball or jet nose have AR of 1, more or less, whereas a wing will have an AR that is greater, at least 3 for it to work as intended, 5 or 10 (or more) leads to increased aerodynamic efficiency.
Anyway, the high AR forces the fluid to pick a side as it flows around the wing - the shape drives the flow. Some flow will sneak around the end of a finite wing, creating the tip vortex, but for the majority of the length, the wing separates the flow into two distinct streams.
An egg presents a fairly uniform obstacle, so the flow is free to move around it on all sides. Flow behind the body depends on its shape - an egg or baseball will have a wide wake zone, generally turbulent (bluff-body wake), a streamlined jet will have a stagnation point at the end somewhere.
A GP is a high AR body, so I was thinking of that when I misspoke in my previous post. I said 'there is no stagnation point in 3D flow' and should have finished with 'around a high aspect ratio body' to make it a correct statement.
PS a ridge anchors the stagnation line, but does not necessary make the flow symmetrical - a canted blade will not have symmetrical flow. A wandering stag. line causes flutter via pressure fluctuations; the ridge stops the wandering.
I know, I know…
I hear you and get your point. But my field is fluid mechanics, and there is no such thing as ‘over-analyzing’ an issue like this, it’s what I do. I certainly understand those who want to ignore all the technical talk - many (most?) of my students feel the same way.
then
you must also factor in that the paddle doesn’t just come straight back, it is also piercing or traveling out from the kayak. this would relieve the tip from a vortex that is caused from shedding the flow…the actual water shedding will be away from the tip.
{just feeding the fire}
Best Wishes
Roy
Engineers and over analyzing…
I’ve got a few Engineers as friends and they drive me crazy. No worries since I’m used to it. ;-]
Quaqte from an old manager:
“There comes a time in the life of every project when you need to shoot the engineer and move on.”
Engineer’s Motto:
If it ain’t broke
it doesn’t have enough added features
call it whatever you want.
I don’t care. There is a difference betw. greenland and Aleutian paddles, and a wide variation within both types.
Aleutian paddles
I'm very late to this discussion as I was doing long overdue house cleaning instead of looking at paddling.net.
I made a Baidarka at the Skinboat School in 2003. I test paddled a number of different size Biadarkas in the bay to determine what size I should build. During those trials I used an Aleutian paddle. After those trials, I told Corey that it would take me a while to become comfortable in narrow Baidarks (the one I built is 19" at the water line with substantial flare above) but I absolutely wanted one of those paddles; I found it that impressive! I had only read about Aleutian paddles, and never seen or tried one before. The paddle I made at the Skinboat School in 03' has been the paddle I have used for 95% of my paddling in the nine years since. The rest of the time I use a GP.
Anyone can formulate a argument for anything and it frequently is done on internet forums: you argue "A" and I therefore argue "B". The question of which face is the power face on a Aleutian paddle is a case in point. My opinion is below.
When viewed from the side (with flat side down), an Aleutian paddle has a taper. The taper starts on the ridge side at loom and runs down to near the bottom (side view) of the nearly flat bottom side. The taper is the thickness of the loom minus the thickness of the paddle tip. This taper means the paddle is partially ahead of the hands in use (ridge facing paddler), promoting stability from this orientation as well as from the ridge. If used with the ridge side forward, the same taper would place the paddle partially behind the hands, promoting flutter if used in this orientation.
I was told this is how to hold the Aleutian paddle and now believe it from my 9 year experience paddling with an Aleutian paddle. This "theory" further was tested in late May when a powerboat wake threw my full weight onto an Aleutian paddle just as I was bracing while getting out of my kayak. That paddle, constructed to Renzo Beltrane's plans, is less stout than the bombproof Skinboat School paddles (with a sitka spruce core). The paddle cracked lengthwise on the power face. The crack starting on the surface nearer to the tip, becoming deep under the ridge as it approached the loom. There was no spare paddle among the 20 or so on the trip-lesson was taught. To get back to to the launch site, I had to paddle with the flat face rearward (backwards) to have water pressure close the crack as I paddled. The crack would have opened and maybe the paddle broken if I had paddling with the ridge rearward, considering the bad crack. When I reached the launch site after paddling holding the paddle backwards, my forearms hurt. I attribute this to resisting the tendency of the paddle to flutter when used the wrong orientation. The crack has been repaired with two types of epoxy and is holding up to use. I'm going to carve another paddle to the same plans with a Sitka core for greater strength.
I am not a engineer or trained physicist and do not want to get into discussions about water flow around different shapes; I would be in over my head in such discussions. What I'm offering is my 9 year experience with the Skinboat School Aleutian and two years with the Beltraine Aleutian (he attributes his design to a paddle in the Smithsonian).
Dave
