This is my first public post on Paddling.com; already learned so much reading others! Love this site already.
My question is about unexpected staples (to me as a novice at repairing ABS boats) under the gunwales of my canoe that pin the hull to the inwale. Can/should I take them out to repair cold cracks and if so, how?
Here’s the story: I bought this 1998 OT Penobscot 16 RX a few days ago (for $300); it’s got 5 cold cracks (5, 6, 7, 10, and 15 inches long) It’s got nice wooden gunwales and–other than the cold cracks and some dry wood–is in great, nearly unused condition. I reached out to @pblanc because I’d seen on other posts he had a lot of experience on fixing cold cracks (and much more!). His advice was great, so I thought I should move this whole thread into the public forum so others can benefit /contribute to this exchange. Here’s what I wrote:
…I’m planning to repair them with G-Flex and (maybe) some 2inch glass tape I got at West Marine. My question: can I do this without removing the wooden gunnels? The wood is decent shape and I’ve never taken apart a boat before so I’m nervous about that and trying to do as little labor as needed to get this thing seaworthy! I was think that I could use a dremel bit (#194) to widen and bevel the cracks, fill/sand with G-flex on both sides (putting glass on the inside only) and then fill the cold cracks from above with a syringe without removing the gunnels. Is this a bad idea? And advice much appreciated!
Here’s what @pblanc suggested:
It sounds as if you are on the right track. I have repaired cold cracks using G Flex thickened a bit with silica powder without backing the repair up with a patch and they have held up fine. But I might be inclined to use a patch on the hull interior for the long crack.
You might find that partially removing the gunwales is not as hard as you think. If the wood is in good shape, the screws might back out easily. The screws that are most likely to give trouble are long screws at the stems that enter from the outwale side and secure inlaid deck plates. If you have on-laid deck plates removal is much easier.
Sometimes a stubborn screw can be loosened by heating the head of the screw with the tip of a soldering iron. If you can loosen up enough screws to be able to just lift the gunwales clear of the hull about an inch, you will be able to get to the top of your cracks.
If you can’t loosen the gunwale screws or don’t want to you can still repair the cracks. In that event I would start by guttering out the cracks on both inside and outside as high up and close to the gunwales as you can get. You might need to widen the cracks a little to insure good epoxy penetration to the depth of the crack. You can drill a series of adjacent holes in the crack wide enough and over a long enough stretch to introduce a bare hacksaw blade into the crack and then run it up and down.
Guttering out the cracks is important as it greatly increases the surface area for epoxy bonding. If the gunwales are still in place, turn the canoe bottom side up and try to get some epoxy into the portion of the crack that is covered by the inwales and outwales. A ‘dental syringe’ with a long, drawn out tip can be very useful for this purpose. But be aware that the epoxy is going to ‘glue’ a short portion of the gunwales to the hull which will make them more difficult to remove later should you need to do so.
Although I use thickened G Flex to fill cracks I would use unthickened resin to bond cloth to the hull.
So this morning I unscrewed the metal (brass? copper?) deck plate off of the bow end and began to unscrew the brass screws connecting the outwales to the RX. First surprise was that at least two of the screws were broken (meaning that part of them is left behind in the inwale. Argh! How to get that broken piece out w/o trashing the wood?) The second surprise to me was that (as far as I can see so far, having removed four screws) the whole boat appears to be stapled to the inwale. The staples (or whatever this hardware is called) is, of course, rusty, and solidly embedded in the vinyl. Is this normal? It looks like it was factory done. And should I even try to remove the inwale? if yes, how? I’m thinking I might just loosen the outwales at each end, leave the inwales alone, and try to fix the cracks that way. But it sure would be nice to remove all the wood to make it easier to fix the cracks and so I can refinish them. Advice welcome! Here are photos of what I’m up to:
