Where to buy Dynel and G-flex
I recently bought an old MR guide that has a bigger than hand sized area on the bottom that is delaminating. There is a 4 by 2 inch area in the middle missing the outer layers with the foam exposed. The boat is in good condition otherwise.
I did a search on Royalex repairs and decided to use G-flex. I had thought to use some MAS epoxy and 6 oz E glass as that is what I have on hand. I have also been told that JB water weld does a decent repair job, and have considered using it, but don’t know how flexible it would be.
After reading the many post on this topic I decided on using the G-flex. I also though the Dynel would be good for the outside layer. I though someone might know the best place to get these materials.
I get my G-flex at West Marine
Jack L
Same Here (NM)
Real champion paddlers, boat makers
http://sweetcomposites.com/
thanks
Y’all are great!
Sweets!
Order some peel ply as well for a nice smooth finish! Jen and Davey are great and know there stuff. Am just finishing an order with them myself!
A few years ago I patched a place from
right under my avoirdupois, where the vinyl had worn off the ABS.
I cleared the vinyl off completely, and used two concentric layers of S-glass.
S-glass is the hardest generally available boat cloth, and pretty tough, too. It does not slide quite as easily as Dynel, but S-glass is much stronger.
Choose Dynel only if the top priority is slipperyness. Choose S-glass if the top priority is strength, with a good measure of hardness and resistance to scratching and gouging.
