Which roof racks?
I have a 2023 Subaru Crosstrek. It has raised rails and no cross bars. I have been successful at using foams and putting canoes between the rails.
It is now time to purchase the bars. Should I get the:
  • Thule WingBar Edge (no overhang)
  • Thule WingBar Evo? (extends past the rails)
I prefer the look of the edge, but in the next year I am going to need to start carrying 2 kayaks. I don’t have the mounts for kayaks yet. Would the WingBar Edge on a surbaru have enough room for 2 kayaks?
Which wingbar, and which kayak mounts should I buy?
Thank you!
Welding Machine…
Wingbar Evo and Raised Rail Evo Foot
See you on the water,
Marshall Seddon
The River Connection, Inc.
9 W. Market St.
Hyde Park, NY. 12538
845-229-0595 main
845-242-4731 mobile
Email: marshall@the-river-connection.com
Social: linker.ee/rivercxn
Welding Machine
For carrying 2 kayaks on that narrow roofline, I would definitely go with longer bars that overhang a bit.
I have an Outback and use the Goodboy rack
If you want to load two kayaks sitting hull down, a simple place to start for the length of the cross bars is to add the widths of the two kayaks together plus another four inches or so. The four inches ensures that some of the bar extends beyond the kayaks to give you something to wrap the straps around. Yes, kayaks taper down toward the ends, but not very much near the cockpit where your cross bars will be. I like my 135cm (53 inch) Thule cross bars for two touring kayaks. And I like having the cross bars extend above the door frame a bit because I don’t have to lean inward toward the middle of the roof while loading a kayak alone.
J-Cradles would let you tip the kayaks on edge so you could get them closer together. But, I recommend trying those out before you buy (maybe a friend has them, or make a new friend at a launch). I find that it’s a pain tipping the kayaks on edge to load them into the cradles.
Agreed. Also, getting a secure fit in the J-cradles depends to some degree on hull geometry, at least in my experience. My Bell Rob Roy has a round hull similar to the Magic canoe; it always seemed to be about ready to roll out of the cradles (an older Thule model) so I went to a saddle-style carrier instead.
For carrying two kayaks, the Thule WingBar Evo is the better choice, as it offers more overhang and space for kayak mounts, unlike the Edge. Pair it with the Thule Hullavator Pro or Thule Slipstream for easier loading and secure transport of your kayaks.
