Thanks. Took a look at the website Seems like it might be a reasonable alternative (but I can’t find a dealer in SoCal) so I might not be able to try it out.
Cobra Revision, Necky Spike They are wider than 24", but for most SOTs you need to be a bit wider to have sufficient stability.
How much touring are you going to do? A few miles up to 10 miles these boats would be fine. If you are talking about real touring then you should be thinking a bout a longer boat like a tarpon, I have a seadart 14’ which is pretty good for what you are talking about but not something you are going to play in the surf in.
I would say 10 miles touring would be the top I would expect to do. Mostly just going along the SoCal coastline, playing a little in the surf, going around on bays for a few hours at a time.
A new revision is almost as much as a Hunt Johnson wave witch. I would definitely go for the wave witch, Hunt lives in Encintas and I believe you could come down and try one out.
