I have inherited an old pamlico which was not stored in the best manor. As a result the seats are junk so i’m in search of replacements. Im pretty sure it has been discontinued. It has plastic seats and originally it did have padding on them which long since dry rotted. Are replacement seats available for this boat? The back seat is stationary, but the front one slides on a rail from the center to the front so it can be paddled as a one or 2 person configuration.
TopKayaker has a great stock of parts and they can typically know about interchangability. I also bought directly from Wilderness Systems when all else failed.
What @Jyak said…
TopKaykaer will have all the fiddly bits you need.
I have a Pamlico 145T and Wilderness still makes the boat, I think all the Phase 3 seats are the same in all the boats. (I know they are for the Tempest 170 and the Tsunami 175, though I’ve never compared to my Pamlico.) But giving an educated guess here they probably are the same seat. if you reach out to wilderness they ought to be able to tell you if the seat is the same. (Mine is a 08.)
You could probably pull it (since you are looking to replace it anyway.) and measure the distance between the mounting holes for the seat along with he other seat dimensions are and ask wilderness what the dimensions of the new seats are.
Since I didn’t know which model of the pamlico you had.
but suffice to say if you cant get it from Wilderness directly you can get it from TopKayaker. https://topkayaker.com/
