tradition vs empericism
When I first started WW paddling, there was a new move to 60deg away from 80. Two years later, my new paddles was a radical 45deg, which is where the trend leveled off for many years.
I certainly don’t see any benefit in using high feather angles for WW, even for upcanyon winds (which can be fierce on western rivers). As a practical matter, feather angle to reduce head/tail wind effects is best when at least 60deg (for sea kayaking, I have gone back to 75deg, like my race paddles). Below that, wind will create a lot of torque, making it hard to hold on. Zero feather (or 10-15) mostly creates resistance in headwinds that results simply in more work,not in the the shaft twisting forces medium angles produce.
Then again, I would argue that there doesn’t exist a feather angle that is best for everything. Ever use a bent shaft canoe paddle at high rates, without feathering? Brutally tiring! Unfortunately, we cannot, using technique, feather our recovery stroke with kayak paddles. Thus, kayakers in certain domains find a real advantage to using feathered paddles (slalom, sprint, or marathon, for example).
In WW, I would suggest that for any amount of upriver wind, the benefit of high feather angles is poor given what all else one encounters.
That said, why use any feather? As one poster mentioned, top WW paddlers (like race paddlers) look for any proven advantage. For play paddlers, the 45deg didn’t seem to be enough for dynamic moves, especially where there were rapid side changes under water. Thus, some went o 30. Since that seemed better for most play paddling, why not 10, or 15,or zero? This is where things got interesting. A lot of top play paddlers were actually very quick in trying out zero feather. Oddly enough, very few actually liked it. Of greater interest, they were all surprised, since they couldn’t explain why. A great majority of those experimenters (this all happened about 7-9 years ago)adopted 10-15. “It just works better” is commonly heard.
For creekers, they have not not been as quick to adopt zero to 15, most seem to like 30,and some still stick with 45. There is a small but critical reason- not going through holes (one poster already mentioned this, and punching holes,or getting worked in one, may have the same needs for feather that play paddlers have). Waterfalls. Miss-calculate, and busting a paddle is only one bad outcome (broken jaws, lost teeth are not unheard of). The consensus is, that a bit of feather dumps the load of an impact more than a zero feather paddle, which can, if the blades are both parallel to the surface, cause a lot of ugliness.
IMO, there are far more reasons for people in most recreational kayak pursuits to use zero feather rather than feather. That said, to categorically claim that zero feather is superior, is to discount practical experience of paddlers far more skilled than most of use will ever be. Every discipline has it’s gem of wisdom that others could learn from, and other gems that is only pertinent to their discipline.
