Just curious if this is a big advantage to be able to unzip your spray skirt without taking it off the coaming? Not particularly useful if you keep your PFD zippered I guess.
Zipper
Zippers and salt water don’t mix. Keep it lubricated or else. Vaughn Fulton
Germany
Be sure to copy the complet URL.
http://www.zoelzer.de/content.php?Produkte%2FKanusport%2FBootsausr%C3%BCstung%2FSpritzdecken%2FZ%C3%B6lzer+Superspritzdecke+mit+wasserdichtem+Rei%C3%9Fverschluss&seite=shop/produkte.php&details=441&hauptrubrik=136
http://www.zoelzer.de/content.php?Produkte%2FKanusport%2FBootsausr%C3%BCstung%2FSpritzdecken%2FZ%C3%B6lzer+Superspritzdecke+mit+Durchgriff&seite=shop/produkte.php&details=86&hauptrubrik=136
So we should get rid of our high end …
PFD’s because they have zippers?
cheers,
Depends
Where do you keep your water and whatever else you need as you are paddling?
Zippered Spray Skirts
My OT Adventure XL 139 has a zippered spray skirt and I am thankful that it is. The cockpit is so large I’d probably spent half the morning trying to get it on. As it is I can put the skirt on shore side and step in, zip up and paddle. The reverse is true when I want out at a break or the end.
Never had to lube either the zipper on the skirt or my PFD.
Any day on the water is a great day,
Cal
