Help me identify this kayak
Hello,
I just bought this kayak for $500. I’ve been searching for a surfable boat for a while, an upgrade from my old Pyranha Orca 16.
This kayak seems like it has had a storied life, I can’t find any makers marks or serial numbers, other than on the hatches and rudder controls.
Nearest I can tell it might be a P&H Quest, from 2001. According to this thread about a similar looking layup (Help me identify kayak material).
As a new user I can only attach one photo per post. So I’ll add more photos in my replies.
So no serial number? That would tell you age and what it was. By 2001 most makers were embossing the S/N somewhere on the inside hull or along the stern gunwale.
I have squeezed my head to peer inside each compartment, hoping it might be hidden. But no, I haven’t found any identifying marks. I’m only guessing on the “2001.” Based on the post I linked with the similar material. I’ll keep looking though. If there is a S/N then it was painted over.
I think P&H has a label glassed into the hull inside the cockpit…no idea where, but it is in there.
About layup, when you see both black and tan it is likely carbon/kevlar, but a weave tells nothing of a make/model?
My older P&H Sirius S had a label inside the cockpit on the right side in front of the seat.
Look up a P&H Orion and compare the photos
The one I paddled had a sea cockpit and no skeg but the AI search says some were built with add adjustable skegs
