There’s no difference between these paddles. A paddle is a paddle. Manufacturers just like to expland the product they have to manufacture, stock and distribute. Why are they so myopic that they don’t just give the public what they want - the Sp-ork paddle. Clip a little here, clip a little there, compromise in the middle. One size fits all. Why have one that’s 8 inches wide and one that’s 6 inches wide; one that has an 18 inch blade and one that’s 20 inches. Why not one with a 7 inch by 19 inch blade. Why a 190 cm long and increments up to 260 cm. Some people but 212 cm or 218 cm paddles, so what are they thinking. Then wing paddles and Greenland paddles. Whats the difference between the 230 cm Ikelos and the 250 cm Kalliste or the carbon GearLab Greenland. Pne difference is obvious here.
I can tell you the difference, but maybe you wouldn’t notice. On the other hand, I can tell much difference between thec2
Paddles are paddles. Too many options that don’t matter. How about the hype over high and low angle technique. Why doesn’t somebody develop the medium angle stroke - best of both worlds. Use a 220 cm Sp-ork Paddle. Instead of 99.7 sq in or 110 sq in blades, make them all 105 sq in. I like that. I like that a lot. Go the direction of kayaks, shorter and stubbier. It’s what the marlet wants. I’ll call Werner, Aqua Bound, and Epic and suggested the Grewing Sp-ork paddle. They should like the idea. Its a revolution in paddle design with a square tip for shoveling snow on the off season.
I consolidated my thoughts about paddles a lot from this thread. Why not the Grewing Sp-ork. Most paddlers use the existing High angle and Low angle paddles interchangeably. Many paddlers prefer the high angle paddle for both high angle and low angle paddling. Yet how many paddlers actually know their cadence. How many actually know their speed potential or even care. You can thank me later when they get rid of the fluff and marketing hype to adopt the Mid angle Grewing Sp-ork paddle. Fast food joints made the Sp-ork a household word. Imagine if tablewear followed that trend. Just one drawer slot for Serrated Sp-orks. Table setting arranged with four or five Serrated Sp-orks and pick up any one of them. No embarrasment at using the bullion Sp-ork for soup. Or a teaspoon instead of the desert spoon. Gadds. What a coup.
Go ahead @starmon1, use whatever paddle you choose. As you can see, there isn’t much difference, as far as you know, according to many contributors.
What I suggest rather than collecting opinions is to use the paddle and use it until something about it bothers you. That is what you need to understand, rather than a bunch of suppositions. Does it feel short which makes you reach; is the area of the blade matched to your physical ability (too large a blade might elevate your effort to an anaerobic level - feel like you’re having to pause to catch your breath and feel like your speed is dropping off until your breathing recovers; does the paddle dimensions allow you to maintain a consistent, comfortable, rythemic cadence; does one paddle torque more when the lower edge catches the water and does it tip on the exit (with a high cadence you have less than 1/3rd of a second to correct the blade orientation before the catch; does the performance degrade as you push the paddle harder (can you feel flutter, air bubbles, oscillation up and down).
Converse with other paddlers you meet at a launch site. @Craig_S was generous enough to loan me his GearLab and Ikelos for tryout against my Kalliste. Discuss paddles and ask if you can swap, or go out with a paddling partner. Paddling doesn’t have to be hard. If you think like a mule, you’ll work like a mule.
Try this on your next kayak trip. Launch and sit in the boat. Hold the paddle a little wider than shoulder width apart, which doesn’t influence reach any more than a narrower grip woukd increase reach. A wider grip gives you a bit more leverage, especially if you use a longer paddle that allows a more open chest cavity for better breathing. Another point of criticism that’s unfounded is that it means you’ll have to reach further or it’ll take longer to reset - that’s just not true!
Rest the paddle on the deck. Sit comfortably with your back straight. Arms LOCKED. Rotate at your waist until one hand crosses the center line of the boat. (No need to over rotate or reach - the more you rotate, the more you stretch the muscles and resist the turn, so stop naturally rather than force rotation). The forward blade should be poised over the edge of the boat and ready to drop toward the catch as you unwind. Focus on the cleanest catch you can manage (no splash) as you rotate from your waist, without adding power from biceps and shoulders which remain locked in a paddler box under mild isometric tension. The boat will move.
You’re now in the reversed rotation position, so repeat the dip and rotation. The boat will move a little faster from each stroke. With each rotation, the boat moves faster, which means your rotation cycle needs to speed up a little. After 20 cycles, you will be moving fairly fast, and your cadence has to increase because dipping the blade into the water rushing past the boat will catch and splash water off the forward surface of the blade. All your focus should be on a clean catch. Doing so means you’re stroke is staying ahead of the boat’s forward movement.
By increasing your cadence, you’ll simply compound the momentum and go faster. If you pause, drag slows the glide, and you have to make up for the degraded glide, so remaining on glide is more efficient than increasing speed by .1 mph then allowing the speed to drop by .2 mph, only to take two strokes to get back to where you were; that is evident on a speed graph by jagged spikes. Paddle resistance falls as your boat increases speed, until drag increases and the boat approaches the actual hull speed of your boat (once it hits the sweet spot for that boat, it gets trapped in a trough between the growing bow wave and the water rushing back to fill the void of the passing boat). Then you need exponentially more power to increase speed. You’ll know when you reach that point, because your breathing becomes more labored. You’re lungs can’t keep up with clearing out the CO2. Lactic acid builds up, the red blood cells latch on to the CO2, hormones increase heart rate to rid the CO2, which returns your system to normal. A heart rate monitor can signal that you’re approaching oxygen debt, so does your rate of breathing, as well as the speed readout on your GPS. This is what uncoordinated paddling looks like on a speed graph. Novice paddlers have no clue. The impression is that paddle pause, paddle pause is normal.
This is what the graph looks like when you push as little as .5 mph over your aerobic limit.
Notice a spike followed by a decline, recovery, then a spike followed by a decline . . .
You can’t cheat your body metabolism. Rather than relying on somebody who sounds astute by quoting a matrix to fit a square peg into a round holes, forget the calculations about arm length plus some factor, width of your boat, or your height.
Instead, try sitting in the boat and rotating to see where the blade ends up when you rotate. If that’s too confusing, look at a published chart, or let somebody tell you, but be careful about recommendations. I’ve seen suggestions where the adviser didn’t ask the body dimensions, type of boat or anything. I suggested how to decide paddle length for low angle. Blade area depends on your physical condition and boat. The best explanation of paddle selection was posted in an earlier thread. The person who posted that has a habit of being right.
A higher cadence allows you to use a smaller square inch blade while still getting an equivalent level of resistance as a large blade. Granted that measuring actual resistance and slippage isn’t a simply matter of calculating sq in area, but In theory:
- 107 sq in X 60 spm = 6,420 sq in of resistance.
- 99.7 sq in X 72/80 spm = 7,178/7,976 sq in resistance.
- 60 sq in (+/-) for a Greenand paddle (?).
If the higher cadence with a smaller blade allows you to remain aerobic (yes, that’s one reason for less surface area on a touring paddle, in that it allows better use of energy, and it allows you to swing a longer paddle.
So the question is whether a 7.78 inch X 19.75 (107 sq inches) blade torques more when it hits the water with the lower edge first (of course it’s less consequential when the blade enters tip first - the reason the tip of both paddles are clipped is so they can be used interchangeable between high and low angle - the asymmetric design balances the entry as the angle flattens. Actually, the high angle blade needs more of a clip since it’s wider. Thats why they look similar, because high angle paddlers use the paddle for low as well as high angle. So why not use a mid andle Sp-ork paddle.
The real question is whether you think a narrower 6.4 inch wide X 20.5 inch long blade will torque as much or whether it would it matter (so why not a Sp-ork paddle). Bottom line is it certainly will work. However, what is the cumulative effect of a minor increase in torque on the grip. 80 spm X 60 min = 4,800 repetitions per hour, but only 3,600 repetitions per hour at 60 spm. It really depends on technique and whether you paddle very far or spirited, eh! If you paddle like woodcutter chops wood and look at ducks rather than cover distances, buy any paddle and toil through it. Paddlng doesnt have to be this complicated. Buy a Sp-ork paddle. What do engineers know. The public will buy anything they market. It’s just a sales gimmick, unless you want to maximize comfort and performance.
