I have a 2009 Saturn Vue suv. One of the crossbars is slightly loose. The bolt for tightening it is circular with tiny grooves all around it. It is also stamped with the number 5.
I’m in limbo as I cannot tighten it to use it or loosen it to replace it.
Any one familiar with such a bolt? I can send a photo if needed.
It’s hard to say what you have without seeing it, but it may be some form of “security” or “tamper proof” fastener. You can buy tools for installing and removing these. Here’s a picture that shows some examples:
That’s not a Torx. A Torx has 6 points, that one has 15!!! I have bits for almost every type of security bolt I’ve ever seen or heard of, but that one is new to me.
Try looking in a Saturn Auto forum. Does these links help…
Helpful man described it as a spline socket. Not too rare, should find thru Lowes. He had a full set for $60. Should be able to get single head for under ten bucks. Thanks again!
Well it is not a spline head though it sure looks like it. Tried metric and us sized spline sockets from lowes. either too big or too small, no just right goldilocks here.
Am following carldelo’s advice and just sent an email to McMaster-Carr. Also dropped by my favorite garage to schedule an oil change and showed it to the mechanic. he likes a challenge, says he has some tiny vice grips and another idea or two.
will know next week when I take it in. Again thanks for all the suggestions.
just sold my two canoes and bought a new kayak. had it out a couple of times and love it weighs just 42 pounds and has a lot of glide. need to get this rail taken care of as I want to take it downriver and then review it here.
That looks very much like the threads often found on internal valves for faucets etc. For the life of me I can’t recall what they are called–but they are used to twist new valves into value/spout body when you have to replace the
Is there a specialty high end screw/fastener store in your area? They might have a idea.
Another desperation option that would keep the thread of that bolt intact (which may prove to be a good option) is to have a decent welder tack weld a standard bolt or nut on the end of that mystery bolt. You could then use a common socket, etc, to easily extract that thing. Once removed you could then identify the thread and locate some new bolt with better options…
Thanks!!
Do all the corners have the same bolt?
Wondering if this one bolt is just a one-off someone stuck in there.
Can’t imagine the rack coming with a weird bolt.
I think an experienced welder could do this, maybe with some shielding around the plastic?
If you drill into the nut with a tap you really don’t know how strong this nut is? Might go well or not? Might be tricky doing this sideways with a hand drill?
But I would look to see if there is some web forum for this car? I would expect some owner has lost this tool before and this “how do I remove this bolt?” query has been asked before?
