Wilderness Systems Tsunami 165/175 being made again?!?!
@jyak I think you hit it on the head regarding my findings. So if I do improve, what would a speed be in a 12’ boat that would then translate to a faster speed in a 14? Or is it a thing where you know it when you get there? I suppose one could keep trying out boats and one day the aha moment hits.
And agree on the hijacking. I have had a thread or two highjacked and while sometimes I want to say “hello, stay on topic”, usually I enjoy the sidetrack as well.
@Shadepine - On the other end of this thinking you have me curious about a longer boat based on your 16’ / 4mph comment, I will have to try one when the opportunity occurs.
There are several approaches to improving speed. Be a gorilla, buyba narrower boat designed specifically for speed or improve on technique and paddling efficiency. Look at the charts on hull speed. It might be an archaic formula, but it gives a great comparison. As pointed out by a few in this post, length give you the potential for speed. There are many opinions about boat lemgth, wetted surface and the impact on drag. Although I can’t prove it definitively, I believe it’s important to understand that a longer boat is typically heavier. For example, consider these rough specs:
175 Tsunsmi, 24.0" wide, 68 lbs.
145 Tsubami, 24.5" wide, 58 lbs
Then compare the hull speed potential of a 14 and 17 ft boat:
Realize that water can’t compress andvit has weight. Consequently, the boat has to push the water aside. Since a gallon of water weighs 8.34 lbs per gallon, every gallon of displacement must be wedged aside by the boat. So th 68 lb 175 Tsunami has a higher speed potential before it gets swallowed by the wake that builds up at the bow and the water that gets pushed aside and returns to fill the void of the passing boat. That is essentially the simplified concept of hull speed. The closer you get to the hull speed, the greater the effort needed to overcome the trap. You reach a point where the boat becomes squirrelly and goes out of control. When you see kayaks surfing, that is no small feat, because the boat is far exceeding the hull speed. It’s essentially planing with the aid of a brace to keep it from tumbling out of control. But that’s a simplistic explanation.
My opinion is that the quest for speed begins internally. You need to analyze your stroke. By developing your technique, you can applybit to any boat you paddle. You can approach it with brute force or start slow and analyze each phase of your stroke for wasted energy. You eventually reach a point where you need to put in far more power than you see any benefit. That means you are approaching the theoretical hull speed. You’ll feel likevthe boat is climbing a hill and filling backwards. When evyou mote you reach that point. You need a longer boat. That isn’t a scientific answer, but it’s what I figured out by paddling harder and getting nowhere. 14 ft seems to be a sweet spot. The boat tends to be easier to control and manuever, and the speed is manageable.
If you find it easy to reach 5 to 5.6 mph in a 14 ft boat, you probably could us a longer. Paddling a longer boat isn’t necessarily easier. It just gives you the potential.
When I look back at my logs over the years, I find avg speed jumping all over the place. Since focusing on my paddling technique, my speeds are predictable and repeatable. Analyse your high angle stroke and low angle stroke. Consider how much of the cycle is transitioning from exit to catch and what part is providing power compared to transitioning between the exit and catch.
I watched a demo on you tube of a kayaker test paddling a Zephyr kayak (Camano paddle). I noticed two details about his technique. First, the paddle oscillated up and down through every stroke. That showed me he was overpowering the stroke and simply wasting energy. The “Shovel Back” connection between the shaft and blade causes turbulence and cavitation that reduces the power of the catch. Compare that to the clean faces of the Kalliste.
The other issue was how he executed turn by dragging the paddler on the inside to rotate the boat or by back stoking on the inside of the turn. Although effective, it doesn’t make sense to blunt momentum when an edge manuever is just as effective.
Without suggesting he should exert more effort, refining his technique could add 10 to 15% more speed.
If you’re interested in specific points that have helped me, DM and we can go into more detail.
It’s interesting how the difference of 3 feet amounts to only 8/10 MPH. I am sure this is an average, but I bet it’s pretty close.
In the world of kayak design we usually see a slight narrowing as length increases. But not always. In the Sea Lion line and also in the old Looksha line the beam was very close from the shortest to the longest lengths, and in these 2 lines the width increased a little as length increased. In my buying and selling I have had them in several lengths each.
Length and deck height were the the 2 things that were very apparent in moving from the 3,4 and 5s in each line.
In buying and selling (and keeping a few) kayaks I have had the chance to paddle most of them. I believe that width and the type of bottom a hull has make more dramatic increases and decreases in speed then length. Not that the length doesn’t…but a 21" wide, 15.5 foot kayak moves forward with less effort then a 17 foot 4" kayaks that’s 25" wide.
And a rounder hull has less surface then a hard chined hull, so that can factor into speed too. Think of a section of an Octagon VS a section of a round as an illistration (if both were the same diameter)
So does rocker. A hull with more rocker has more surface to push water with and also the drag given by water needing to rush back into a void made by the sudden loss of displaced volume of that curve as the kayaks goes forward. But all gains come with some corresponding loss in some other way. Shorter rockered kayaks turn MUCH faster and easier then long low rockered kayaks, but are slower in straight lines.
How do you get both extreme speed and extreme maneuverability? Simple answer: You Don’t!
The “rocker” you need to use to turn fast in a long kayak is the sides. So in such a kayak the skill must be developed to turn such a kayak about 45 to 75 degrees on it’s side and edge it for fast turns, and that means having a skirt and having enough skill to use that technique. Skill cannot be bought. It has to be developed. Just like a good skill at forward paddling. All of this is about skill building.
So there is no right and wrong here. There are just different designs made to favor different factors, that may or may not be appealing to different paddlers.
Indeed one has to make compromises. I could perhaps use a bit longer design, but that is not made anymore and it would possibly also diminish my fun paddling in the short waves of the lake IJsselmeer here that I enjoy too.
Also I’m lucky that where I am paddling, there is very little chance of damaging, otherwise I would use a much stronger boat too.
JYak you might look over the specs on these 2. If the trade war comes to a good end it may be worth consideration. But with duties 25% tariff and brokers fees I’d say the cost is likely too high for now. I am hoping this all levels out soon. But Thor (my very large friend) is looking hard at a Mastif and the Gnarly Dog is close behind it in size.
My plastic Tsunamis are virtually indestructible. They comfortably fit my parameters regarding size and fit, and I also value the handling characteristics.
The only change I’d seek is a lighter weight, but the weight is an unfortunate feature of owning a plastic boat. I’m not willing to commiit that level of investment just to shave a few pounds of weight. Besides, the more I carry it, the stronger I get.
I only paid $1,599 retail price for the 175 Tsunami, and about $1,200 for the 145 Tsunami. Both were exceptional values that continue to serve my needs. As I always say, if it ain’t broke, you don’t need to fix it. My conclusion is that if I want to enhance speed, the best fix is to improve the power source.
I have on good authority, Steve who worked for Wilderness, told me that the Tsunami was patterned after the Artisan Millenium. It is wider than the Artisan.
Well I can’t fault that thinking. And I now have some “high end” kayaks, but I also see a real need for keeping at least 1 Roto-molded kayak, due to their near indestructability. So for 5 years I have bought and sold many kayaks and up-graded my little “fleet” as I went along. But now that I have been able to paddle a lot of them and gain some understanding of features and design differences, it’s hard to argue with the fact that a GOOD poly kayak is an excellent kayak to have in the collection. For anyone that paddles in various conditions in some places that may be unfamiliar or harsh, I still can’t say much bad about a good roto-molded kayak. Rocks and rough shores that make be be extremely careful with my Rebel kayaks are insignificant to my Chatham17. I have no experience with the Tempest, or the Tsunami lines from WS but all I have read makes me believe they are equal to some of the better roto-molded kayaks I have owned and used.
I want to end up with 4. As of now we have 9. So I will sell a few to make room, and because the up-grades keep me from using the very good ones, favoring the excellent ones. But if someone was to want 1 kayak to do as many things as they could from rivers to open water to sea travel, I would ALWAYS recommend a roto-molded kayak, which I find myself in opposition to many other fanatical kayaks saying. But that’s my honest opinion. Sure, they are heavier. and you must keep them out of the sun for storage (but a simple shading cover is often enough.) But they are 1/2 the cost of a high end kayak (or less) and they are very capable craft with the benefit of being so tough that all white water boats are made from the same material and in the same way. When going to some new place and not knowing what launching and landing spots you’ll be using, a roto-molded kayak is a great choice.
If the Trade Wars level out and most of the countries that mave the better makers in them drop their tariffs down, the cost of GOOD roto-molded kayaks may become reasonable again. In touring types the WS kayaks are perhaps the only options left to the American buyer as of right now. Eddyline is moving back and sold to Dagger, but they make Thermo-Formed kayaks and I own one, A Fathom. Excellent kayak, but not as tough as a roto-molded kayak.
Only having WS as an option may not be all that limiting however. The WS offerings have proven to be excellent in the past. The fact that the longer kayaks seem to have been dropped is a concern, but if the few American makes see the market opportunity knowing all competition is foreign made now, it may be a good place to re-stimulate the market.
God alone knows. But despite the fact touring kayaking is falling from the main focus, with fishing and rec kayaks as well as paddle boards out selling them, having 100% of 4% of the total market is still a very good business opportunity.
Of every 100 kayaks sold in the USA today about 4 of them are touring kayaks. If that 4% gets divided up it becomes less then exciting from the standpoint of manufacture. But the counter dynamic is if WS (or anyone) were to do good marketing and re-open the lines so all sizes and weights of paddlers could get a good fit from them they would probably open that 4% up to themselves and nearly stand alone as THE place to go for that need to be met.
To my knowledge in rotomolded touring kayaks 16 FEET OF LONGER made in the USA today, we have WS with the Tempest and the Tsunami lines ----- and there may not be any others right now.
I think WS should try to capitalize on that fact while they can.
@Shadepine nail = head.
@ kapungo read on below it may help you out.
My fleet is all wilderness systems.
I have a tsunami 175, a Tempest 170 and a Tempest 180 Pro.
The theoritical math on the hull speed is
Tempest 170 6.358 Mph
Tsunami 175 6.451 Mph
Tempest 180 6.542 mph
You’ll note that they are all within .1 mph of each other
The fastest I’ve run all the boats under average conditions (flat water, 10mph or under wind) is
Tempest 170 - 5.7 mph (3 Mile Race course.)
Tsunami 175 - 5.8 Mph (3 Mile Race course.)
Tempest 180 - 5.9 Mph (3 Mile Race course.)
These are all touring hulls, the tempest 180 and the Tsunami have the same beam and the Tempest 170 is narrower. yet the max sustainable speed I can push them each pretty much follows the hull speed calculations minus about 1 mph.
So I after padling these boats, I kind of use a rule of thumb that based on hull speed alone I can (when in race shape.) push the boats more or less sustainabily within 1 mph of hull speed. this gives me a good measurement of how well I might perform in a touring hull at a given lenght.
and just to muddy the water further… because I can.
I have an aspire 105 Pure rec boat and wide as S*hit at 10.5 feet long. it’s hull speed is 4.997 mph. I’ve pushed that successfully at 4 mph, in average conditions as a sustainable pace.
So I would posit that you are completely correct that the beam really matters less than the length.
Steve, this is for you, so other readers need not follow it because it might be TMI. No debate that a 15’ 6" x 21" kayak moves forward easier than a 17’ 4" x 25" kayak. However, in reply to @kapungo, it’s important to note that a shorter kayak isn’t necessarily slower, it just has a lower speed potential than a longer boat. Longer doesn’t mean faster, and I agree that the narrower (and possibly lighter) boat is initially faster, but it can’t reach the same top speeds, which can be explained by belaboring the concept of hull speed, regardless of the way it’s calculate.
To reiterate, water cannot be compressed, therefore, it must be displaced to allow the boat move. The displaced water can only be deflected down, or get pushed aside, but it eventually flows back to fill the gap made by the passing boat to find equilibrium. How efficiently it does that depends on the hull form, the configuration of the chines, the width, draught, and to a somewhat lesser degree the texture of the hull (see archives about waxing the hull). It all influences efficiency, but it is the length of the hull that sets the speed cap of all displacement hulls (the hull speed formula fails to address specially designed hulls like the surf ski, race boats, and catamarans, otherwise, the simple hull speed charts are close enough. The accompanied charts show how when the hull length matches the wave length, it traps the boat between the bow wave and the water that fills the gap the passing boat displaced. The graph roughly represents how resistance builds as speed increases. There is a sweet spot where power output becomes exponentially greater than the increase in speed. To me, how fast I can go is less important than how much I benefit from the effort.
This topic is so theoretical it induces “ho hum” reactions. I only repeat it to emphasize the reason hull length is a limiting factor rather than a magical speed enhancer. A longer boat typically means a heavier boat, which if all things are equal, heavier means more displacement. My assumption is that two boats that are identical externally but with one weighing 20 lbs more means that the heavier boat will be slower. The reason- it displaces more water. Therefore it sinks deeper. Water weighs “about” 62.4 lbs or 8.34 lbs a gallon. If you consider that a boat must push that weight aside to move through water, the most efficient wedge design will push forward with the least resistance.
That brings the paddle into the equation. If the hull is designed to part the water more efficiently and ease the inevitable rush to fill the void, it’s only logical to conclude how a paddle that provides the most resistance is the most effective. As long as you don’t feel fatigued from lifting the overall weight of the paddle and your cadence allows you to control the paddle placement, you have a great paddle. However, supporting a heavy paddle for extended periods, swinging a high cadence, or have issues with accurate placement for a splashless catch, are reason to consider upgrade to a lighter paddle. Before you decide on a paddle, analyze the features of the blade and how it attaches to the shaft
Many paddles advertise a blade with dihedral, which balances the way water flows off the power face equal . . . The pause is intended to make you think. If the function of the paddle is resistance to push the boat forward, how much dihedral should a paddle have to move the boat. Technically, the answer is as close to zero as possible. Greater dihedral improves the balanced feel as the paddle “moves” through the water, but the ideal paddle doesn’t move at all. So the paddle you select should be the one you control best. If your paddle is fluctuating up and down, oscillating, cavitating where you feel bubbles, you’re dumping power. Asymmetric blade designs are intended to balance the way the blade contacts the water. The trapazoidal design should be more clipped brcause it catches at a lower angle, but for some reason, both high and low angle paddles seem to favor the same geometric shape, with the high angle featuring a wider but shorter blade with greater area to compensate for the lag during the transition from exit to catch. Greater blade area typically results in higher anerobic demands. That’s benefits full power sprints that can be sustained by an athletic person, but it seriously limits endurance. One caveate is that the closer you get to the hull speed of the boat, the less efficiently the hull will perform. So a longer boat simply extends the hull limit. At my personal level of conditioning, I can cruise in the 145 at around 4.75 mph and the 175 Tsunami at close to 5.0 mph over about 8.5 miles. I purposely avoid peak speed except to test the force of the waves. On moderate waves, I can repeatedly hit 6.4 mph to 7.1. Larger waves can drive my peak speed to 8.3 mph. That exercise allows me to assess the impact the waves will have when I reverse direction. My strategy, right or wrong, is based on assessing the conditions so I can tackle them most efficently. The focus is not speed, but continuity and efficiency. I’m confident that if I can reach a specific speed over 8 miles, I can sustain it for 20 miles, and my logs support it.
The Greenland paddle relies on cant to direct the flow of water in a controlled fashion. Cant doesn’t improve the power transfer, it just augments control, and the “typical” symmetric design offers technical advantages for rolls, sweeps, and braces. If a paddle tends to fatigue you and the technical advatages aren’t critical, you might be adequately served by using smaller square inch blade.
So if I understand the question that @kapungo asked, it was related to comparing the speed in a 12’ boat to the relative advantage of paddling a 14’ boat. The data I logged over the years is limited to only four kayak models, with all being Wilderness Systems products with similar build and identical seats. Several points make the WS brand desireable for my kayaking needs, starting with:
*reasonable pricing (retail prices ranged between $999 through $1,599);
*each model has the unique multi-chine hull design which is responsible for the incredible primary stability and very predictable secondary stability; I rarely ever feel the need to brace in under any conditions and find that balance is easy, even when encountering breaching waves from the side. The last thing I want in a kayak is the need to fight it
*the seat system when I was shopping was rated as one of the most comfortable seats available, and still is rated highly; the adjustable high back seat offers great comfort for long hours in the boat, although it is less suitable for reentry compared to a backband;
*the roomy cockpit and high front deck is amply proportioned for a large paddler. The Pungo has the lowest deck at 14", but the cockpit is an open design; the 125 is 15", the 145 is 16" and the 175 is 15.75"; the Pungo is my favorite kayak. Even though I don’t paddle it anymore, it is the go-to kayak for guests because it’s so forgiving. Although I paddled it in open water and crossed the bay multiple times, it’s fast, but not as sea worthy or controllable as the Tsunami.
*rocker is minimal and tracking is very controllable through edging, except for the 175, which requires rudder input to control weather cocking as winds approach 10 mph; turning isn’t an issue for me since I value tracking over turning, but my trips tend toward touring in active open water. Although each model handles the open water of the Upper Chesapeake Bay, the Tsunamis are best suited when conditions are flagged Small Craft Advisories. Then the 175 is the best performer. I don’t go out or will get off the water if Gale Force Conditions are warned. I don’t wear a spray skirt, so I’m not comfortable with winds gusting over 30 mph.
140 Duralite Pungo (14’ x 28", 43 lbs, 400 lbs)
125 Tsunami (12’ 9" x 26", 52 lbs, max cap 300 lbs)
145 Tsunami (14’ 6" x 24.5", 58 lbs, max cap 350), and
175 Tsunami (17’ 6" x 24", 69 lbs, max cap 400).
I also own two rudder equipped 140 Tsunamis, and a rudder equipped 145. Unfortunately, I can’t fit in either model because the clearance needed for the rudder movement limits the extent of leg room, but that is not a problem with 175. Relicatingbthe 145 seat ti thecrear baba scant 43 mm upset the balance and made the kayak uncontrollable when following waves push the boat over 6.4 mph.
To emphasize our previous conversations, I am not a technical kayaker and believe you have far greater boat handling skills than I’ll ever pursue or achieve. I believe you’re also a far stronger paddler who is capable of reaching greater speeds and distances. I base that on our conversations, the behavior of your paddle that we both have adequate experience with., and your experience with paddles from a Taiwanese snow shovel, many styles up to the Kalliste, which has a blade area that may be insufficient for your powering strategy.
When assessing the design factors that contribute to hull efficiency, you have to consider how the hull floats, how it reacts when pushed through water, and how to propel the boat with a paddle which involves not only propulsion but control as well.
I’ll warn that perception is a poor method to assess performance, although it is the primary way to judge stability, comfort, and a sense that you are connected and able to control the boat. The reason for the inadequacy of perception is the conflicting forces and sensations that you’ll experience on the water. That includes:
*proximity to stationary object, land, other paddlers and the movement of floatsom on the water surface, which all create an illusion (for ex: witness the perceived size of the moon on the horizon vs. when it’s directly overhead, and measure actual speed when paddling alone, as compared to paddling into the wind when bracketed by other kayaks in line abreast. The higher the wind, the greater the resistance and the slower your speed. If you add a contrary tide combined with a river outflow which accentuates the waves, the sensation is exhilerating and reminiscent of a scene of speeding PT boats in the John Ford classic, “They Were Expendable”. I’ve had adjacent paddlers remark how fast we were going but didn’t have the heart to tell them we were going 1.5 mph faster when the wind was to our back and the tide in our favor.
*the sensation of actual wind and perceived wind (for ex: paddling at 4 mph into an 8 mph wind gives the perception of a 12 mph breeze, while paddling with the wind at your back cancels the felt wind, then a side wind still offers another impression.
*level of exertion which varies with conditioning, and largely depends on how you encounter wind, waves, tides, and currents.
*the testing intervals and parameters have to be the same, the conditions need to be repeatable, and the sample large enough to show that the results aren’t spurious (for ex: testing for maximum speed can’t really be relevant to assess glide or how long it takes to get up to speed).
Several methods can offer valuable data:
*measured distance in a timed interval. Although that might be valid for the specific distances, it’s hard to extrapolate the findings to other boats or how the speeds translate to longer trips.
*GPS is best, primarily because it automatically measures speed, calculates average speed reasonably well, records the duration and distance of the trip, and usually has a clock to tick seconds or at least one minute intervals to count off cadence. I use both the GPS, as well as a phone app that revords speed on a graph to reflect the speed fluctuation. That serves as a black box for post-trip analysis. One thing I notice when viewing speed graghs of other paddlers is wide fluctuations that reflect a range of 2 mph between the high and low speed, or around (+/- 1 mph) above and below avg speed. I believe the best value of a GPS is the ability to bracket your speed to stay within a range of (+/- .2 mph) of your avg speed, which is the best I can seem to manage due to the GPS limitations. The reason I believe condensing those speed spikes has a great benefit is because the graphs show it takes more energy to get up to speed than it does to maintain it. My belief, based on experimenting with various paddling techniques, is that the closer you get to hull speed, speed gains become exponentially harder. If you’re a serious paddler, you probably hit a consistent pace. Rather than trying to go faster, its more beneficial to feel out your boat’s sweet spot. That’s where your power output seems to net the best result. If you’re at the boat’s sweet spot, you might have to put out 10 times more effort to gain an addition 1 mph of speed. Whwn the extra effort elevates your output to anerobic, the consequence will be a drop of 1 mph below avg speed, which depletes energy reserves. It takes at least 3 times more energy to just get back to the avg speed. My best strategy results when I plateau at a sweet spot that lets me predict an avg speed at the outset. If I go outside of the (+/-) .2 mph range and hit .5 mph, the sustainable speed drops below the avg speed for at least twice as long. It takes less energy for me to stay as close to the sweet spot as the GPS allows. Which brings me to cadence and paddles. I select a paddle that allows me to remain aerobic for efficiency and to keep a high enough cadence to sustain the glide. A cadence of 72 to 80 spm allows me to sustain the glide with 20 additional strikes per minute than one stroke every second. The increased cadence helps to manage tracking by alternating the power effort on each side of the boat. The way I look at it, the yaw rate is reduced by half with an 80 spm compared to a rate of 50 spm.
*heart rate monitors and oxygen sensors are probably the best tools to track how you use energy. They offer an accurate window to assess exertion. When coupled with indicated speed, you can correlate performance with actual effort to reach speed.
I’ve also compared my data to stats that @Craig_S shared with me about paddling his 175 Tsunami, 170 Tempest (17’ x 22", 57 lbs, max cap 325 lbs), and the fiberglass 180 Tempest (18’ x 23, 64 lbs, 400 lbs). His stats included some observations about his son’s race performance in the the newer model of the 145 Tsunami (14’ 6" x 25.5", 59 lbs, max cap 350 lbs) and the 170 Tempest (17’ x 22, 57 lbs).
Although we are virual opposites in our paddling technique, we approach the process in a similar fashion. My advice to Craig is to keep doingbwhat he’s doing. Rather than tell you what I think, I’d rather explain why I think it. That way you can accept, reject, or assimilate the info without having experiment.
If anyone got this far and feel cheated, I apologized. If you think its too long, I suggest you scroll down to determine how much of your life will pass before reachung the point. If anyone has questions, DM me to save the innocent bystanders who just want take in the wonders out there.
That’s interesting, but Im.having a hard time envisioning that elegant boat superimpised over the puggish brute I see in the Tsunami line. It does look a bit closer to the 170 Tempest.
To put my dissertation in perspective, it amazes me that the difference between the referenced boats is so minimal regarding speed, but the different dimension do alter performance, load capacity, tracking and comfort more significantly. I hooe some of the comparisons will shed light on how versatile the kayak design can be. Speed isn’t everything.
Is that the model?
I found the same plateau as you, even though you have more detailed records. Shadepine’s figures are slightly skewed, but I believe they’re still consistent because his calculations are not directly correlated with distances - the numbers look right.
I like the speeds you reach in your Aspire. It supports a point that Steve made about the shorter but narrower boat reaching speeds faster. Although the boat he references is narrower, hitting the lower theoretical hull limit is easier in a short boat, if you have the power to push it. That supports the concept that longer isn’t necessarily faster. It just extends the potential, while making it harder to reach or exceed the hull limit.
When I started paddling in the 9’ 6" x 30" Swifty, I learned first hand about the concept of hull speed, because I pushed the boat so hard against the bow wave, the stern would bury under water to within a few inches of the cockpit coaming. I eventially upgraded to a 12" x 28" Liquid Logic, which eliminated that problem.
Raw unabated power will only last as long as the limited energy reserves stored in your muscles. To my chagrin because it contradicted my theories of paddling efficiency, you’re able to exploit high angle technique for both sprinting and touring. Until paddling with you, I didn’t associate high angle with efficient touring.
The formula does not fail but changes for different designs.
Hull speed in knots can be calculated with the formula S/L*LWL^(1/2) with the boats Length of the WaterLine (LWL) in feet and the Speed/Length (S/L) ratio varying from 1.34 to 1.51 for slender hull shapes up to 2.2 for Sprint Kayaks and Canoes.
The S/L also depends on the shape of the hull at the waterline and perhaps even beyond that, as the waterline changes because of different trim at different speed.
We should just acknowledge that hull speed is more complicated than longer is faster.
That I don’t doubt. this is why I say what I state as it pertains to touring or rec-class because this is where I have real world numbers and I can account for the engine and it’s performance.as I can gather data on my O2 consumption heart rate and other biometrics. and compare it to my speeds in various hulls I own.
but I refrain from talking about racing hulls as these are wildly different.
I was out this weekend. doing a leisurely 5.7 mph in my Roto Tsunami 175. over a 4 mile course. when I ran into a girl in a Racing OC1 outrigger. we paddled together for about 1.5 miles and I was able keep up with her on nothing more than sheer strength willpower and determination whereas I don’t believe she was breaking a sweat. we were doing 5.9 mph for that last bit.
now her boat and I’m not sure I’m classifying it correctly. was about 6-8" wide at its widest part and the seating position was about 6 or 7" above the waterline where it flared out to about 16" wide. for the cockpit.
It would have been a complete tip machine save for the fact the outrigger worked as a counterbalance for tipping right and a float preventing flipping left. She told me there was no rudder or skeg it just steered by shifting weight left or right and at 24 ft it had everything to be a fast mover.
very similar to this:
That’s a far better explanation, which is why posting on the forum is a good oppotinity to flesh out and elaborate on a topic. At the time the hull speed equation was formulated, most ships were designed for cargo capacity and the hulls were full to accommodate merchandise. That was true even for warships, until I believe the French started refining the lines of the hull to make them faster. That evolution resulted in the Frigate style ship, and ultimately the Baltimore Clippers and the China Clippers.
That skips a lot of history, but it’s worth mentioning the Chesapeake Bay Log Canoes that evolved from a singke log dugout canoe into the three log versions that were slim, elegant, long, and loaded with sails. Watermen learned to modify the hull form until the class of boat was so highly evolved, the hulls resembled the advanced computer designed shape of modern naval destroyer.
The sailing crowd seems to be more knowledgeable about hull design than most who follow the sea. Back then, boat builders lofted full size hulls from half models. It’s surmised that owners found that the boat sailed faster on one tack then the other, so that is how the form advanced. So then you had to figure out who had the faster boat, and who was just the better sailor.
I know enough to grasp the concept, but even if all the variables are know to work the equation, most of us would just buy the boat for its beauty, comfort, performance or durability, based on reviews. I have a conceptual dream boat and the finance to buy what I want, I also value speed and efficiency, but I paddle a plastic wash tub. Despite my elaboration about the value of a GPS and analysing the “computer data” from a phone apps to evaluate the parameters of trip performance, in the end, all I really do is paddle until I start breathing hard then back off. That works kind of like a tachometer and a vacuum gauge on your car. Go figure, right?
I don’t bother to factor in the actual water line length either. I just round down.
Then why bother with “hull speed” at all, as any touring kayak longer than 14 feet (at the effective waterline) is fast enough for touring purposes. More length is mainly an advantage then for taking more load aboard without disrupting a good “streamline”:
That is because they are designed that way to accommodate heavier loads aboard, although it can be some advantage to a cruising speed.
I remember paddling a 17’ and 18’ Grumman canoe with about 500 lb aboard, where the 18 feet one felt easier to paddle.
Because new members ask. I learned by trial and error, starting with trying to figure out why the 9’ 6" Perception Swifty tried to bury the stern under heavy paddling effort. I’ve seen the topic about boat length and speed multiole times. Long term members givebuo answering the question, member with less time on the forum answer with more abbreviated versions each time the topic surfaces. It’s like edging, rudder, skeg. It isn’t resurrected due to disagreement. It resurfaces to inform new blood.
I guess we’re like Guinness, sour mash whiskey, or yeast starter - the recipe always has a common flavor because a little of the old mxes with a little of the new.
The reason I like the old hull speed formula is that it that it may not be the most accurate, it is the first historic attempt to answer the question with a mathmatical solution to understand the phenomenon. If you start there, the scientific evolution can expand on the issue. Just like now. The best reason is that the hull speed chart shows the speed in nautical miles (which is what the formula actual shows, but it also provides the conversion to statute miles and to metric.
The great thing about kayaks is the history that links the most advanced tonthe ancient. Despite the advances in technology, the application of the scientific method, computer calculations, and wisdom of time, padders are still using skinny sticks and skin on frame kayaks. All that while we have access to exopy reinforced bullet proof fabric, feather weight carbon fiber paddles, GPS to pinpoint not only out location, but to plot our course, find our way, estimate our speed . . . Still others prefer a chart and magnetic compass. What lineage!
Good question. Why bother, because now we know. With all the formula options, when it comes down to it, we compared a few different boats of different designs, materials, and dimension. When compared by several different people, we find that the speed difference is only about a few tenths of a mph. Then we gained insight into how each design performs under different conditions.
Craig gave me the opportunity to compare the Werner Ikelos and his carbon fiber Geralab Greenland paddle to my homemade Greenland and Kalliste. I hope to try out 180 Tempest (I’ve already sat it so zi know I fit) and his son’s new model 145 Tsunami that is 1inch wider than my 24.5 inch model. The problem is finding the time, at least it gives us something to look forward to. Being inquisitive can be time consuming.
A good and quick overview and set of observations. But in the world of kayaking and canoeing the foundation in most cases is the love of “old ways” If improvements in propulsion were truly central, no one would use any kayak or canoe. We’d all use power boats.
But humans are interesting and varied animals. Some love horse riding in the era of cars. Some love hang gliding in the era of jet travel. Some really odd and mysterious men like to hunt with flintlock rifles in the era of high grade automatics with large scopes (Be very careful of those guys. They are REALLY weird)
People like what they like ----- and other people look on and wonder why.
Indesd a strange world. As @kanoniem pointed out, why concern over hull speed at all. Indeed, why? Because of inquisitiveness. Why use kayak, because I can, but with all of the resources within my reach, why a plastic tub? Because it’s cheap, durable, comfortable, and it has proven itself adequate for the task and the challenge. Best of all, it also challenges me to be better. In a way, going to a more capable boat might derive me of the challenge. Now that isn’t actually true, but I like to believe it. Truth is that my kayak is like an old shoe or coat.
Most Marylanders, especially those living in proximity to the bay, have traveled the waterways to some extent, including me, if not for pleasure then for fishing or crabbing. My bay access had been mostly through family members or friends, because so many power boat owners boast about the two happiest days of their lives - the day they buy the boat and the day they sell it. Conversely, I’ve never regretted my purchases, aside from regretting being timid about delaying the investment.
When I first started kayaking, my nephew described crossing the bay on his ski jet (not to cast derisions on 'all" Ski Jet owners, because I consider them a bane to the waterways - i haven’t witnessed those “wave boats,” but too many Jet Ski owners seem to delight in behaving like gnats). His journey impressed me as an unattainable goal (how naive of me). As my level of skill and the suitability of my kayak fleet improved, I was able to realize the goal by kayak.
Although I’m not a technical kayaker, I’ve explored the full Upper Bay, the creeks, rivers and tributaries, from the entrance to Baltimore Harbor up to the foot of navagability below the Conowingo dam on the Susquehana, and from the dam to the navigable waters below York, PA. Maybe not as beautifully varied or as exotic as site posted on Pretty Pictures, or as challenging as surfing the oceans fringes or negotiating rock garden, but the kayak has allowed me to fullfil an unrealized lifetime dream of exploring the range of the bay.
I say this jokingly, but if I were to buy a Gucci boat, I’m not sure I wouldn’t be inclined to tow one of my Tsunamis behind it, which is the way I see the tug boats pushing barges up the channels. Now I fully appreciate the desire to just sit and take in the beauty, but I’m just programmed to explore what’s around the next point. The kayak has allowed me to trace the path of early explorers like Captain John Smith (I’ve explored his area up to 20 miles north and south of Jamestown as well).
That’s quite a return on an investment for a $1,599 boat, a $450 paddle, and a $150 PFD. I’ve also invested in a $299 GPS and $139 VHF radio (and one replacement for each). I’ve seen exponentially more than all of the power boat rides throughout my life. The gear is beaten and weather worn, but the bungees have been restored and the seat covers are new. I’m ready for another season, and it don’t get no better than that, unless I can encourage some reader to give it go. Nobody in my present company has any desire to venture a return trip - too much like work.
